LS 400 Issues
Old Jun 9, 2012 | 05:03 PM
94ncls400's Avatar
94ncls400
https://www.clublexus.com/forums/ls4...ange-pics.html
Old Jun 9, 2012 | 07:03 PM
j2b4o's Avatar
j2b4o
Originally Posted by 94ncls400
http://media.photobucket.com/image/e...empsens007.jpg
https://www.clublexus.com/forums/per...-i6-sc300.html
For others who may run into the same problem, this will help all. I will be checking into this and attempt the replacement myself if I can. Otherwise, its a trip to the mechanic. Tnx!
Dont sweat it, the hardest part is pulling off all the plastic on top lol. It's easier than changing a tire
Old Jun 14, 2012 | 08:56 PM
94ncls400's Avatar
94ncls400
Well the ect sensor was changed, not too much of an issue there, but OMG the fuel filter was lengthy! Started at 6 and finished at 9 or so. I made the mistake of putting in several gallons prior to the job. Every last drop of those damn gallons drained out of the filter! Almost stripped one of the nuts because it was acting stupid! URGH!!! So anyway, I FINALLY get it off, switch filters and test the car. I had some seepage, so I turned off car and tightened. 2nd time was good. Here is the changes from the two services;
Idle smoothed out
MUCH BETTER acceleration from 1 into 2 and 2 - 3. Still some gurgling but it will at least it will merge into an intersection quicker
No more hurky jerky at stops
I still have some hesitation and I believe it may be due to either the plugs, wires or timing, SOMETHING is causing the "jigajigajiga" sound when I initially pull off and when I rev/go into gears. Truthfully, it sounds like a car/turbo car running open exhaust, just not as loud and raspy. Its hard to trouble shoot since I have no idea what signs of timing issues are. I dont drive it all the time and too far just yet, but I may go by the dealership and have them test the timing as although the original over says he did the timing belt and timing settings right, he may have dropped the ball.
But 2 broken nails, a shirt doused in gasoline,1 eye ball slapped with a drop of gas and tools covered in spatter, I did EVERYTHING by myself and it was the 1st time working on a lexus. I use to watch my dad work on rotarys so I know a few things.
Old Jun 15, 2012 | 03:43 PM
94ncls400's Avatar
94ncls400
Im going to see if I can have a flow test or something on the exhaust and see if theres any blockage.
Old Jun 19, 2012 | 10:42 PM
94ncls400's Avatar
94ncls400
Well I got good news and bad news. Good news is I got some ignition coils, ran them and the car opened up great, then loud chugging and hesitation was gone. Bad news is I was so eager to install them that I relocated ignition coil 1 and stretched/twisted the almost 300k wiring going to the bottom of the coil connector, so much that I snapped the wires. NOW, when I try to turn it over, it will crank, turn over for a second then cut off. Is there any way I can fix the break? Maybe solder or some flux or electrical tape etc? If not, is there a way I can buy a new connector, then just splice the wire somewhere and redo the harness? I need some ideas because the lex is on the side of the road. Thanks guys!
Old Jun 20, 2012 | 12:24 AM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
you or any auto-electrician can cut/extend/solder/heatshrink the wire back together.
Old Jun 20, 2012 | 06:20 AM
94ncls400's Avatar
94ncls400
I dont TOUCH electrical wiring and I am not able to posted a wanted or service ad in the classifieds. Guess it will be craigslist or a formal call for help here.
ATTENTION ANYONE IN THE CAROLINA/WAKE COUNTY AREA, IF YOU ARE ABLE TO DO THE ABOVE, I WILL COMPENSATE YOU FOR YOUR TIME IN HELPING ME DO THIS TO THE LEXUS. AGAIN, IT IS ON THE SIDE OF THE ROAD AND I AM NOT FAMILIAR WITH ELECTRICAL WORK. THANK YOU.
Old Jun 20, 2012 | 02:03 PM
PureDrifter
BahHumBug
CL Folding 100,000
you will be wanting to post that here...
https://www.clublexus.com/forums/southeast-22/
Old Jun 20, 2012 | 04:12 PM
Lavrishevo's Avatar
Lavrishevo
If you snapped the wiring going to a connector then the easiest thing to do is find your car at a salvage yard and cut or have them cut that cable off for you. Of course, leave lead wire on the connector. Go to radio Shack of similar and buy a cable crimping kit. Comes with the crimps and crimp / wire stripper. Then just match your colors and wire the new one in.
Old Jun 26, 2012 | 02:01 PM
94ncls400's Avatar
94ncls400
After finding no replacements from the junkyards I've called, the countless on holds, the ignorance of the local parts stores and a no call return from johnson lexus in raleigh, I was forced to take off the heels and get dirty again. This is the end result. Mind you, I have NEVER done ANY KIND OF WIRING to a car...
Relocated ignition coil 1 near the battery for the moment. After I can get someone to help do the s\heat shrink and fine clean up of the wiring, the rest of the remove and install of the old then replacement coil can begin.
Old Jun 26, 2012 | 02:13 PM
PureDrifter
BahHumBug
CL Folding 100,000
working wiring is better than non-working wiring. at least now you can drive it to an electrician's shop.
Old Jun 26, 2012 | 05:28 PM
cobalt91's Avatar
cobalt91
Good work. You got this far, I think you can finish it up. Just take your time.
Old Jun 29, 2012 | 09:33 AM
94ncls400's Avatar
94ncls400
Thanks but Im scared I'll botch something up. if I try to cut or shorten anything.
DefconFx
Oct 3, 2013 11:38 AM
Bankswood
Jun 25, 2013 05:44 PM
Gil Smash
Aug 24, 2011 10:57 AM
weezie
May 8, 2006 11:45 AM
wolver1ne
Maintenance
Jun 15, 2003 02:36 PM
