crank shaft pulley
crank shaft pulley
How do I remove the crank shaft nut? Im trying to do a fan bracket 93 LS. When I try to break it loose it just spins the crank. It not going well. I need help anybody out there know?
from my timing belt experience here.
https://www.clublexus.com/forums/ls4...n-ls400-2.html
wedged an large allen key into the flexplate through the transmission access panel to lock the motor from spinning while removing the crank bolt, no need for any special tools
