I got a question for you audio guys out there?
This question is for those that only truely know. Dose the Gauge of the speaker wire you run make a difference in the sound of a car system?
This article is super old, but I was buzzing through it and it was filled with a WEALTH of information, which I pass on to you (I'm going back to read more, lol)
http://www.hydrogenaudio.org/forums/...howtopic=14082
subs? or just door speakers? I kno with all my sub set ups I run 0 gauge cable I've used 2 gauge wire before and had problems with the subs cutting out. i guess it all depends on what kind of speakers your talking about, in door speakers I cant hear a difference
This is the facts here. You do not need 0 Gauge wire to your subs. 14 to 12 gauge will suffice.
If you are running a lot of current/amperage. The gauge of wire is also dependent on how long the run of wire is and how much current is going through it. You can drop a gauge if your wire is say 6 feet instead of 12 feet. There is a electricians table for current and wire gauge with the variations in length mixed in on the internet somewhere. Should be easy to find.
I am doing 400 watts and only using 4 gauge wire for power wire. My amp is a high current amp also. The amp can do 800 watts and I got that 4 gauge wire because it would handle the 800 watts the amp was rated for.
IIjzXXL
12-04-06 03:09 PM
Scott1258
10-12-06 10:24 PM
Michifan12
01-21-05 11:25 AM
fever
11-09-01 11:14 AM
