98 ls400, what should be the proper idle rpm?
after cleaning the throttle body and tightening up the throttle cable i believe my rpm's dropped. when in DRIVE GEAR standing still my rpm's are between 300 and 400. When I turn the AC on it raises to 700-800.
when in PARK gear with ac off i get around 650.
is this right, because i sense a bit of vibration when i hit 300 rpm.
I'm experiencing nearly identical symptoms in my 97 LS400 aside from sudden increase in RPMs when Drive is selected, followed by a moderate thud. Placing the gear selector into reverse is not near as sever, but Drive appears to load the motor to a 400 RPM. Normal driving appears to be unaffected aside from a general lack of power.
I have searched and searched the web and lexus specialty sites, but to no avail. Does anyone have a clue what is going on here???
Thank you,
Justin
Thank you,
Justin
Hi GX470GT.
Did you reset the ECU after cleaning the throttle body and tightening up the throttle cable?
Air passage changes require the resetting the data which is stored in the memory. The ECU needs to set up the new condition. In order to do this, simply remove the negative side of the battery terminal for a minute with head lights on. Then connect it and you need to run until the temp gauge goes up enough.
Hi GX470GT.
96UCF20 (12-16-16)
gp2m
69
05-08-21 08:48 PM
sulliman
29
04-15-13 05:08 PM
vintagekar
01-29-13 07:20 PM
