Problem
Old Jan 1, 2011 | 04:42 PM
alvaro31's Avatar
alvaro31
Default Problem
I have a 1991 Ls 400 an i vend having these problem wth it when i go step on the gas my car wont go it buggs then after couple of secons it will go like if it not getting gas. but i plug my scanner n i get a code IAT, and mixture control continuously lean. how can i cheak my IAT or give me a tip?
Old Jan 1, 2011 | 05:59 PM
phxls400's Avatar
phxls400
Default Your issue
Honestly it was a little difficult making out what you were saying, but I think I was able to decipher it:
I'd certainly replace the IAT if your scanner is complaining about it. Its an easy part to get and replacing it on a car with 100K+ miles makes sense.
Also have you looked into doing the typical maintenance of replacing the plugs/wires, and also taking a look at the throttle body for carbon build up etc.
I bought a 93 not to long ago and went through it in one day to do the above. Car ran spectacular after just a bit of maintenance.
I had some bad build up even on the side where the EGR valve was, i took it off and there are two "holes" that had alot of nasty carbon where the the valve was. It ran like crap. Once I cleaned it out with Throttle body cleaner, it ran SO much better and instantly passed smog as well.
Our car's are typically owned by a generation of people that had $40K+ and "just wanted it to run" -- which means they did not typically do maintenance on them.
I'd start there but that's my two cents.
akafixture
Apr 28, 2016 03:20 PM
MADLEX
Jul 31, 2012 07:08 PM
Lust4Lexus
Maintenance
Nov 22, 2011 10:26 PM
calichris
Apr 7, 2008 12:56 PM
porshapowe
Jan 31, 2007 10:58 PM
