that looks awesome imo. definitely something people would buy.
the only input i have is maybe have the visor come out a little bit further so its more of a wing. but im really feeling the "down turn" everyones referring to. i think its just right.
looks sick!! but i also am not a fan of the downturn. i would definitely purchase one and im sure i know a bunch of people from hawaii would also. im gonna keep my eyes peeling for this one
hey sorry for the lack of updates. imperium- i started by making a template with masking tape of the top of my rear window. then transferred that to a piece of cardboard and cut out some different shapes to mock up. when i found the look i wanted, i used the cardboard template to trace the shape onto a 3/16 sheet of abs plastic. cut out the blank a bandsaw and mocked it up on the car. with it taped in place(centered and whatnot) i marked where the corner bends would start and end. got a large diameter piece of pvc pipe (3-4") to use as a form to make the bends and heated up the plastic where i marked it before with a heat gun. then put the heated plastic over the pipe and let it bend and cool to take the shape of the rounded corners. after that was some sanding for final fit and finishing. its held on by some 1/4 wide 3M adhesive tape. im failing at getting pics up sorry but ill see if i can get more detailed ones up this week. good luck!
i fail at updating sorry guys. as usual my ADD kicked in and i started another project getting the car ready for paint. i got side skirts on, got bored, and came up with this
heres a "in progress" shot. i took the body line out of the front fender cut a vent and started the bodyline from where the vent leaves off and it will rejoin the original line about where the door handle is. hopfully ill finish this project before i start another one haha. next is paint
the rear visor is off getting prepped
celsiorlee- the wheels are 20x9 20x10 Riverside TrafficStars
