EASY 93-94 LS400 $3.00 CLuster Flicker and Gas needle Fix
#106
Capacitator Lexus LS 400 91
Hi, I'm new in this forum
I understood the capacitators C142/ C147 are the ones related to fuel indication on Lexus LS400 93-94.
My question is if the Lexus LS400 91 have the same capacitators number or different ones.
#107
Yamae,
Where can you order the parts for cluster repair and would you send picture and or video to my email.
debarb@bellsouth.net.
I am speaking for parts listed in #103.
Thanks,
Zwolle
Thanks,
Zwolle
#108
Yamae,
Thanks,
Zwolle
Thanks,
Zwolle
Was it not available or a failed unit and you want to fix yours?
Regarding the post #103, you'd better ask Chopfooey for the detail.
#110
Many of those old voltage regulators are not designed to use too low ESR capacitors. See the page below.
Without an additional countermeasure to prevent the oscillation or the unstable operation of the circuit, you'd better use electrolytic capacitors.
http://www.tij.co.jp/jp/lit/an/slva115/slva115.pdf
#111
Same Board, new problem
Hi everyone- Several years ago I used this forum to repair my dash by replacing C147, C142, C214, and C212, and it worked great for a number of years. Now it stopped working again, so I ordered the specific electrolytic capacitors that Yamae recommended in this forum. Unfortunately, the problem is now in a different area not mentioned, and those previous repairs are still good. One of the original caps has melted and burned a small part of the large board, just above the blue connector CNB, and about 2cm to the right of C108. I think the burned one says C106. Can you tell me what type of Capacitor this is? Also, the back of the board is slightly burned and a couple of the board leads are gone. Does anyone have a picture of the back of the board where C106 goes, so I can attach jumpers to bypass the missing lines? THANKS!
#112
My problem on my 1994 LS400 is when the car is cold inside the cluster will not light, after driving about 45 minutes with the heater on they light up and work normally. This problem does not show up in the summer when it is warm. Will replacing these caps fix my problem?
calaveras (11-13-18)
#114
That would be electrolytic caps. Digikey has multiple selections. Just look at the illustrations on the site and choose. They are really inexpensive. Mine never failed to eventually light up but it was taking longer and longer over time.
#117
Just bought a 1995 with same issue. Anyone know if they are the same?
Update:
They are NOT the same. The newer 1995 model doesn't use any SMD caps at all, they're all round can with two legs thru the PCB.
I've ordered new caps in these flavors and quantity:
(Name brand low ESR caps not the cheap stuff)
1x 50V@10uf
2x 50V@4.7uf
2x 50V@1uf
2x 25V@820uf
1x 25V@470uf
2x 25V@47uf
1x 10V@470uf
1x 10V@180uf
Update:
1x 50V@10uf
2x 50V@4.7uf
2x 50V@1uf
2x 25V@820uf
1x 25V@470uf
2x 25V@47uf
1x 10V@470uf
1x 10V@180uf
Trying to locate the correct Caps to buy now.
#118
WOw... I apologize about being from the "Texting" generation. my language can be a bit rough at times. In an attempt to write something that would help people save money and gain appreciation for their cars I got complaints about my language! I don't care if you like it or not... Take the knowledge and information and run with it!
PS Lexus owners seem to act like poor Porsche people!
Oh and someone email me a question about this...
How did I ever manage to find a Momo steering wheel hub for the Ls400\Sc400 when they don't make them?!?! The trick is to use a 96-00 Civic EK hub. you can even use the $10 kind on ebay! its a direct fit but you have to figure out how to wire the horn up... thats the only tricky part.
Thanks again all!
Thanks again all!
Brian
#119
A 95 has newly designed and totally different boards. There is no compatibility at all and there's no correspondence. I would use an ESR meter and find out defective capacitors, if the problem was only related to capacitors.
#120
Lots of picture taken of the board and the Caps. Will post here.
I am trying to confirm where the Odometer reading is stored on the board, as my car has low km (just over 200,000) compared to the 300,000km on the dash I have just purchased. Any ideas?
