EASY 93-94 LS400 $3.00 CLuster Flicker and Gas needle Fix
Old 03-11-15, 07:04 PM
  #91
lexmoose
lexmoose's Avatar
Part deux.
Originally Posted by Rice4eveR
Do the same for c142 and c147 located on the big board! C142 is to be replaced with new capacitor 4.7 Uf 25 volt and c147 is to be replaced with 10uf 50 volt.
Super small
Bend and cut the legs into feet like the one below
Don't burn yourself with the iron!
Old 03-11-15, 07:08 PM
  #92
lexmoose
lexmoose's Avatar
Part three
Yeah like the pic says... I screwed up and ripped off the copper lead rushing, so I took a probe and scratched the green coating off the board so that I could have a new spot to solder
Looks great and doesn't flicker anymore, cold or hot! I hope I don't make the dudes that charge hella money on eBay mad... but ****um! half of them charge to much for the service anywaY!
As always I had a blast teaching you somethin' new!
Thank you for reading!
Rice
If the moderator could edit the first post with the pictures this would help a lot.
Chopfooey (04-27-17)
Old 03-12-15, 06:07 AM
  #93
jvote
jvote's Avatar
Default Thanks
Thank you for the re-post. I greatly appreciate it.
Old 07-20-15, 06:04 PM
  #94
1bcbbcb
1bcbbcb's Avatar
Hi, so Ive got a 94 LS400, I really like it, but the gauges console is often completely black when I start the car and then flickers to lit when it wants, usually 1-5minutes after being on. What are the best options to do this, because getting a whole new panel is quoted at $500.
Old 07-21-15, 10:37 AM
  #95
TaninAuto
Sponsor
CL Vendor - Starter
TaninAuto's Avatar
Do it yourself or send it to us to do for you.
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
www.taninautoelectronix.com
Old 04-07-16, 06:45 AM
  #96
hirbo
hirbo's Avatar
So I tried to fix this myself. Was able to solder things fine. However when I soldered c212 I didn't put it in an angle and when I tried to put the cover back on it seems I ripped the cap and the contacts out, as you can see in the picture. Anybody have any ideas on how to fix this giant f*#@ up.
I am going to the junkyard this weekend and hope I can find a 93/94 with the cluster still in it.
Old 04-07-16, 06:56 AM
  #97
Michael
Michael's Avatar
You are not going to find a cluster from a junk yard, I can assure you. Your best bet is to find a contact point using amp-meter and re-solder. Cluster is a surface mount so the soldering is not an easy work.
Old 04-07-16, 07:40 AM
  #98
Yamae
Forum Moderator
Yamae's Avatar
Don't worry. Solder the new capacitor to the lands indicated by the red circle + and the black circle - after removing the surface coating
Attached Thumbnails EASY 93-94 LS400 .00 CLuster Flicker and Gas needle Fix-location-to-solder.jpg
Old 04-19-16, 06:25 AM
  #99
hitachi
hitachi's Avatar
okay so i just started learning this soldering thing and this post did wonders for me especially with the photos and opened up possibilities i never thought possible. any way i wanted to make clear that the area for these capacitors are not through hole then? and if i wanted to make a new spot to solder like you have how do i know where to make a new spot?
Old 04-25-16, 03:28 PM
  #100
DoktorYes
DoktorYes's Avatar
I had the same problem with my cluster going black for a few seconds 45 to 60. Replaced the caps on both boards,1994 LS400, great fix. Yes their are clusters to find. I got one at Pull place for a 1994 LS400. Got it for the needles, pointers on my were going dim. Only paid $27.78 plus tax. I guess I was Lucky to find one, just keep looking.Oh by the way replacing Caps Will fix many other cluster problems, gas gauge, speedo, lights around the interior of car, many more to list. Try it you will be Happy With the results!!!!!! Dont forget the transistor 109.Change it to.
Old 04-25-16, 08:27 PM
  #101
Yamae
Forum Moderator
Yamae's Avatar
For 93-94 LS400 owners, I recommend to use following capacitors for your cluster fix.
For C212 10/16V,
http://www.digikey.com/product-detai...37CT-ND/817534
For C142 4.7uF/25V,
http://www.digikey.com/product-detai...41CT-ND/817538
For C147 10uF/50V,
http://www.digikey.com/product-detai...43CT-ND/817540
Above those costs less than $2 totally. The shipping cost may be more than that. I recommend you to change the ECU capacitors if not done yet buying all capacitors for it too at the same time.
Old 04-25-16, 08:54 PM
  #102
Michael
Michael's Avatar
For C212 10/16V,
For C142 4.7uF/25V,
For C147 10uF/50V,
Just what the Doctor ordered. Thanks Yamae.
Old 04-27-17, 10:23 AM
  #103
Chopfooey
Chopfooey's Avatar
Just bought a 1995 with same issue. Anyone know if they are the same?
Update:
They are NOT the same. The newer 1995 model doesn't use any SMD caps at all, they're all round can with two legs thru the PCB.
I've ordered new caps in these flavors and quantity:
(Name brand low ESR caps not the cheap stuff)
1x 50V@10uf
2x 50V@4.7uf
2x 50V@1uf
2x 25V@820uf
1x 25V@470uf
2x 25V@47uf
1x 10V@470uf
1x 10V@180uf
Old 05-03-17, 02:22 AM
  #104
lucasv555
lucasv555's Avatar
Hey buddy,
I am very new to this forum. Dont know if iam doing anything wrong, but i cannot open the pictures you have posted regarding
fix of the cluster for LS400. I do have the same problem as you are mentioning here. Tried to you webpage, but it looks like the
link is dead. Can you help me out here ? Can you send those pictures and instruction to my mail lucasvs84@gmail.com
Old 05-03-17, 03:40 AM
  #105
Yamae
Forum Moderator
Yamae's Avatar
Originally Posted by lucasv555
Hey buddy,
Did you see the post #91?
Quick Reply: EASY 93-94 LS400 $3.00 CLuster Flicker and Gas needle Fix
