front clunk.. wheel hitting steering?
Old Mar 13, 2010 | 06:13 PM
posdriftin's Avatar
posdriftin
this is what tie rod is hitting inside the rims.. looks like support brace for wheels..idk...
and here is hub pic with wheel off
Old Mar 13, 2010 | 10:10 PM
JimsGX's Avatar
JimsGX
If the 1st Gen LBJ's were updated to a 2nd Gen, would that make a difference? I've never had the opportunity to compare the design of the 1st and 2nd Gen LBJ designs side by side. Would the 2nd Gen ball joint arm push the tie rod end further out toward the rim?
Old Mar 14, 2010 | 01:29 PM
Legionofon's Avatar
Legionofon
loosen that bolt on the threads of the tierod and clock the tie rod just a tad so that its out of the way, I would also recommend a alignment
Old Mar 14, 2010 | 06:23 PM
posdriftin's Avatar
posdriftin
Originally Posted by Thermactor
It sounds like you have nothing to lose, can't you take a dremel and grind a little bit of material off the offending ridge on the tie rod end?
lol trying to fix it right not just rig it like previous owner..haha
Old Mar 16, 2010 | 08:26 AM
posdriftin's Avatar
posdriftin
it seems like the whole hub is closer to the wheel... wonder can cause that.. i put spare rim on because it doesnt have those ribs like other rims do... any idea what would cause hub to move backward? cant be strut rod cause whole wheel would move yeah?
GS4TEK
Jul 13, 2012 10:31 AM
TXFM
Dec 7, 2008 05:23 AM
GsCruiser
Feb 22, 2008 02:15 PM
girlilove
Sep 21, 2007 04:34 AM
koreanpers
Jul 28, 2004 11:37 AM
