Over heating
Old Jan 17, 2010 | 11:29 PM
kelley5795's Avatar
kelley5795
Default Over heating
A day before my car blew a head gasket, I had seen that the Coolant gauge had stopped working Why would it just stop working? the cluster is new, Because If it would have been working It would have maybe saved my car , So Im fixing this after i fix everthing should it work or did the Coolant Temperature Sensor go out? Or is that the sensor that tells the gauge witch way to move?
Old Jan 18, 2010 | 10:11 PM
trukn1's Avatar
trukn1
NELOC Mod
Sounds like it could have been a faulty sensor or even a bad thermostat. To be on the safe side I would replace both of them since they are not expensive to replace at all. Honestly,, you need to figure out what clogged in the first place causing you to blow a head gasket. This is pretty much a very rare oddity in this car.
Old Jan 18, 2010 | 10:18 PM
kelley5795's Avatar
kelley5795
Well when the head gasket blew, The thermostat was gone, like the heat took it out, butI know i need a new thermostat but what Sensor do i buy?, other then that idk
Old Jan 19, 2010 | 02:22 PM
3UZFTE's Avatar
3UZFTE
The thermostat can't jsut disappear, someone very well could have removed it, but they don't go *poof*. There is a temperature sender and temperature sensor. The sender tells the gauge what temp the engine is, and the sensor tells the ECU what the temp of the engine is.
bk2thamax
Mar 17, 2014 07:38 PM
AMSMIKE
Dec 15, 2013 03:17 PM
sethjon
Feb 20, 2011 02:50 PM
whiteivory
Oct 24, 2010 06:39 AM
Haus
Aug 3, 2010 09:47 PM
