Panfilo's 90 LS400
Old 10-23-14, 06:53 AM
  #31
BigBalloo
BigBalloo's Avatar
i know this threads been dead for a bit . but i had a quick question. how much clearance did you have on the front brake calipers ?
Old 10-23-14, 01:29 PM
  #32
dicer
dicer's Avatar
? I understand it on a hot rod, but a 4 door sedan?
Old 10-23-14, 03:17 PM
  #33
timmy0tool
timmy0tool's Avatar
UCF10s have regular sliding calipers which are pretty small in profile so front clearance will be minimal, all depending on wheel offset and spoke/pad design.
Old 10-25-14, 06:05 AM
  #34
BigBalloo
BigBalloo's Avatar
The reason i asked is because i was thinking about getting a set if 338s and wanted to know if they would clear the 2gen ls bbk. I called the company but they didnt have that info. The wheels are 18x9.5 -4
Old 10-25-14, 08:35 AM
  #35
sha4000
sha4000's Avatar
Are they high disk, low disk? Either way with that -4 I'm thinking they will clear.
Old 10-27-14, 05:07 PM
  #36
timmy0tool
timmy0tool's Avatar
-4 might still not clear if the disc is not correct or too low. high disk is what you want!
quick google on 338s show a company called boss. those do NOT look like high disk to me however 10-15mm spacers will remedy this.
Old 10-28-14, 06:51 AM
  #37
BigBalloo
BigBalloo's Avatar
timmyotoool
yeah to me they also look like low/normal
thanks for the reply . should be getting the wheels sometime this moth coming up.
Jofosho
Build Threads
03-20-15 03:02 PM
hotdawwg
30
10-18-12 04:48 AM
CRAZYLS
03-03-12 05:53 PM
Max Power
14
08-27-09 01:55 PM
Griffin400
31
01-08-08 05:08 PM
Quick Reply: Panfilo's 90 LS400
