1998 LS400 -- does failed O2 sensor require replacement?
Old Sep 2, 2009 | 01:20 PM
xyzzy_dude's Avatar
xyzzy_dude
Question 1998 LS400 -- does failed O2 sensor require replacement?
My 1998 LS400 with 175K miles is throwing a P0161 OBD2 code, which appears to indicate a failed O2 sensor. I have cleared it and it came right back so I doubt it's a transient condition. I've noticed zero difference in the performance or smoothness of the car, but my gas mileage as reported by the trip computer has improved significantly, from 23-24 to 26. I know the O2 sensor helps with setting the fuel/air mixture, so I'm guessing my car is now running much leaner.
Leaving aside considerations of OBD2 emissions inspections, is there any downside to just leaving it? I seem to be getting better fuel economy as an upside.
Old Sep 2, 2009 | 04:51 PM
Lanson's Avatar
Lanson
That's the heater control circuit failure of the o2 sensor. Could be the heater circuit itself, the connector, the sensor's circuit, etc. Go under there and check it out.
If you run too lean, you'll start killing things. Be careful, and replace it soon.
lexisaurus
Apr 22, 2017 09:23 PM
Bluv
Nov 9, 2015 01:28 PM
st1013
Jan 19, 2015 03:32 PM
techiedude
May 2, 2012 06:57 PM
rod
Maintenance
Oct 25, 2005 01:26 PM
