seat problem...
Old May 24, 2009 | 11:29 AM
dann707's Avatar
dann707
Default seat problem...
i got a problem with my seat....i recently bought a 93 ls and when i try to lean my seat back only the left side goes down and the other side stays up......what can i do.......?
Old May 24, 2009 | 12:27 PM
JAndersson's Avatar
JAndersson
See this post on LOC for a solution on your problem:
http://www.lexusownersclub.co.uk/for...howtopic=57102
Old May 24, 2009 | 07:58 PM
qha_vn's Avatar
qha_vn
thanks Dann for your question and JAnderson for your link
i have got the same painful issue for 2 years and now know how to fix it. I once thought that I would unplug the wire so that some one would not be able to lean it down (normally in car wash service or repair workshop)
Old May 27, 2009 | 07:56 PM
RAINBOW's Avatar
RAINBOW
I just fixed my 93 with the same problem. Take the back of the seat off (2 screws) and on the bottom you will see the aluminum rod (covered with blk plastic). I took a hammer and smacked the rod to the right, and it still would not turn or recline. So I smacked it to the left(and it started turning) and I could see the splines on the right weren't engaging. I used two small hose clamps and a piece of metal that grabbed both parts (hard to explain) and now the right side spline turns with the aluminum rod and the seatback reclines. Don't ask me to repeat this ! Also look at the seat that works, it will help you understand the problem.
JAndersson
16
Dec 4, 2017 07:06 AM
Coolpop
Dec 2, 2014 09:33 AM
Bozookah
Mar 8, 2010 12:42 AM
biglexass
Jul 16, 2006 03:31 PM
MarsB007
Apr 15, 2004 01:55 PM
