What's wrong with your LS?
Old Mar 19, 2002 | 11:45 PM
Lvangundy
Guest
Posts: n/a
That's an L in my name, not an I by the way :-) :-)
I wish there was some kind of 'ask jeeves' answer wizard here who could help with all these problems.
Old Jul 29, 2003 | 10:16 AM
Lexozz's Avatar
Lexozz
Here's what's wrong with mine
1 The A/C fan does not spin fast enough, car overheats. It seems no one can help me solve the problem.
2 The drivers door handle is broken
3 Psngr side mirror is slightly burned out, bright lights in the night are now a nusance.
4 P/S pressure hose is leaking $265 just for part, labor????
5 Heated seats don't work, never did!
6 Telescopic steering works when it wants to.
Last but not least (everyone's favorite) the $%# instrument lights are going and the bulbs are hard to come by and too damn expensive for every part Toyota/Lexus makes.
WTF
Old Jul 29, 2003 | 04:15 PM
VVT-i's Avatar
VVT-i
Man,this is an old thread.
My best guess on the overheating problem is too much dirt bluid up between Condensor and Radiator. Just remove the plastic covers on top of the radiator and remove 2 12 mm nuts that hold the radiator bracket and push back the radiator. You'll be surprise how much dirts,leafs and debris are collected between the Condensor and Radiator. I hope this help.
Old Jul 29, 2003 | 06:55 PM
Losiho's Avatar
Losiho
1) The very low idle that other people complain about.....doesn't stall, but idles at around 400rpm. (I'll get them to check the TPS / TB / VAF at service (car is under warranty)
2) The passenger side rear door globe in the ashtray is blown.
And that's all ! Otherwise, it looks, smells and drives like new.
Old Jul 29, 2003 | 08:24 PM
tleader's Avatar
tleader
Default 91' LS 400
I have a 91 with 174K on the odometer, and it runs like a champ. I bought it for $2600 and fixed a few minor problems, but everything works great except the A/C display.
-Fixed the O2 sensors, suspension, and minor wires that were disconnected.
-few dings form the previous owner.
-ready for a new clear coat on the paint.
All else is well.
Old Jul 29, 2003 | 11:38 PM
persian451's Avatar
persian451
i fixed so much stuff on my car and still have more to go:
repaired:
timing belt/ water pump changed
alternator
starter fuel injector seals and other seals involved with repair
egr valve/pipe and modulator
all shocks replaced
hood shocks replaced
replaced jammed caliper
2 main o2 sensors
replaced MAF, for some reason broke (luckily got it for 200 bucks @ junk)
all 3 cats replaced with old ones (for some reason mine had holes in them)
front seats leather redone
AC display fixed
one CV boot replaced
Things need 2 do:
bushing for the front and rear
engine & tranny mounts
body shop on quarter panel dent and hood (might a crap load of money)
front bumper needs repainting
Old Jul 30, 2003 | 10:05 AM
Pagong's Avatar
Pagong
1990 LS with 143+++ miles
power steering pump - replaced
timing belt- replaced
water pump- replaced
front brakes- serviced
oil changed with Quaker State
known problems
driver seat right side motor doesnt work, only one side reclines
passenger seat doesnt recline at all
small dings and dents
tires are almost worn down
front ball joints
EGR valve
needs a drop and a new set of wheels/tires
other than that the car is great, it just takes some care to make a car like this drive and ride like new again. Just keep up with the maintenance and everything should be fine.
Old Jul 30, 2003 | 11:39 AM
TRM04's Avatar
TRM04
97 LS400.
No MAJOR problems except the car vibrates like hell between 45-65! Tires are fine and in balance....dealer can't figure it out...
afpj
Mar 13, 2011 12:09 PM
sparky3
Jun 4, 2008 11:22 AM
Nauticalx
Hybrid Technology
27
Jul 17, 2007 02:20 AM
NewLSlover
Aug 11, 2006 07:26 AM
tvd51
Apr 7, 2003 01:50 PM
