LS 400 will not start
Old Mar 27, 2009 | 06:53 PM
jmcintire3's Avatar
jmcintire3
Default Ls 400
Is the ECU like the brains or what??? thanks
Old Mar 27, 2009 | 07:47 PM
DietrichB's Avatar
DietrichB
Spray a little starting fluid in to see if it will fire.
Did you check the fuses? Maybe the injection isn't getting power.
Old Mar 28, 2009 | 05:02 AM
qewani1's Avatar
qewani1
try to press gas pedal for two times before turning the key to start position.
check all things which are related to the starting of engine from fuses relays..sparks..alternator..battery..air..fuel..
Old Mar 28, 2009 | 05:23 AM
python's Avatar
python
Originally Posted by LiCelsior
i agree with diagnosing but tune ups are not a waste of money....
throwing tune-up parts at a "no start" car IS a waste of money
Old Mar 28, 2009 | 10:11 AM
AzHotLS's Avatar
AzHotLS
Before you start guessing on the repair . . .
Hard to start or extended cranking
Old Mar 28, 2009 | 10:46 AM
jmcintire3's Avatar
jmcintire3
Default Ls 400
I have checked all the fuses with a volt ohm meter, all good. Which relays should I check out? And how do I check the relays? What is the ECU? thanks for all the input
Old Mar 28, 2009 | 10:54 AM
LiCelsior's Avatar
LiCelsior
Retired
CL Folding 500,000
ECU is the computer.
Old Mar 28, 2009 | 03:03 PM
jmcintire3's Avatar
jmcintire3
Default Ls 400
I tried the starting fluid, and pushing in the gas pedal, nothing.. Is there any way to tell if the computer is bad?
Old Mar 28, 2009 | 07:22 PM
DietrichB's Avatar
DietrichB
If you have spark, the starting fluid should have done something. Check the new cables and make sure they are routed to the right cylinders.
Old Mar 29, 2009 | 04:49 AM
python's Avatar
python
something tells me u made a bad situation worse
Old Mar 29, 2009 | 09:00 PM
EastWind's Avatar
EastWind
this is hiliarious, i had this same stupid problem and got 10000 different advices, i wasn't sure what it was. i took it to LEXUS and paid $110 for a diagnostic fee and they couldn't figure it out. they suggested that i have to change the distributor cap and rotor before they can figure it out.
i did that and my car is good and solid since then. if you haven't tuned up your car, tune it up, tune up is not a waste of money, if you are going to keep your game, tune it up first before any major work.
KISS
Old Mar 30, 2009 | 12:01 PM
jmcintire3's Avatar
jmcintire3
Default Ls 400
I thought the starting fluid would do something as well, but it didnt. So replace the rotors and caps even though all cylinders are getting a spark? Could it be that its getting too much gas? thanks for all the help
Old Mar 30, 2009 | 03:30 PM
python's Avatar
python
KISS
if the lexus dealership could NOT determine that a car had a no start due to an ignition problem then they have no business working on cars....spending money and throwing parts at a car that has a no start problem and could be a fuel issue IS a waste of money....hope u dont work at a repair shop.....SMOOOOOOOOOCH
Old Mar 30, 2009 | 04:15 PM
AzHotLS's Avatar
AzHotLS
Which brings me to my next "Bit O Wisdom": Mr. Shop Owner, Is your repair "a guess" or "a fix"?
Old Mar 30, 2009 | 07:14 PM
DietrichB's Avatar
DietrichB
If the firing order is correct, and you're getting spark, and the starting fluid doesn't do ANYTHING, check timing, it may have slipped way out, or the belt might even be broken.
