First LS...problem. Noob
Old Jan 25, 2009 | 12:30 PM
OJEST808's Avatar
OJEST808
Default First LS...problem. Noob
Hi, can someone help answer this question. I just recently purchased a 1991 LS400 that was sent to a mechanic shop because it overheated. The mechanic said it was just the radiator. The vehicle could start an be moved around for just a bit. But recently, just when I bought the vehicle...it will start but dies out right away. I checked the radiator fluid an it seem to have some on the low line. Just wondering if these vehicles have a sensor or something thats stopping it from starting now. I'm in the process of changing the radiator but also wondering if there's something else I should be changing also. Any help would be appreciated. Thanks
Old Jan 25, 2009 | 12:36 PM
LiCelsior's Avatar
LiCelsior
Retired
CL Folding 500,000
u could also change the engine coolant temperature sensor. search and you'll find pictures and step by step tutorial.
Old Jan 25, 2009 | 12:50 PM
OJEST808's Avatar
OJEST808
Thanks, will do. But will those two problems stop the vehicle from starting?
Old Jan 25, 2009 | 12:56 PM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
check the maf to make sure it's good, then fuel pump, filter, and reset the ECU (not in this order)
Old Jan 25, 2009 | 01:05 PM
OJEST808's Avatar
OJEST808
Thanks. Hope i can get it up an running soon.
2JZSC3oo
Oct 12, 2012 06:56 PM
Luxurexus
Feb 15, 2012 04:49 PM
gs300ctn94
GS - 1st Gen (1993-1997)
May 6, 2010 05:11 AM
3warnes
RX - 1st Gen (1999-2003)
14
Aug 4, 2006 11:24 AM
kendogger2002
Maintenance
Dec 10, 2002 06:38 AM
