problem with oxygen sensor '91
Old Jun 28, 2008 | 09:25 AM
cgholson's Avatar
cgholson
Default problem with oxygen sensor '91
I had a code 28 on my 91 ls400 that the oxygen sensor on the right before the catalytic converter was bad so I replaced it. Right after that the car still stalled and a code 24 came back saying intake air temperature trouble area; open or short in the intake air sensor circuit. Help me please. Where is this sensor located at and can anyone provide a picture of it and advise what I need to do to clear this code? I really need your help because the person who has my car doesn't take anything about this sensor and I've been without the car for a month.
Old Jun 30, 2008 | 05:57 AM
cgholson's Avatar
cgholson
Default Problem with oxygen sensor
I haven't gotten any replies. No one else has ever had this problem with their lexus?
Old Jun 30, 2008 | 01:57 PM
Bali26's Avatar
Bali26
Hi sorry for the delay.
O2 sensors should be replaced as a pair.
Anyway, Air intake sensor (MAF) is located 4 inches downstream from the air filter. Its in a metal housing with a wire clip on it. Maybe its loose. Its very delicate, dont try to clean it or drop it.
Dont leave your car with someone who does not know what he is doing.
Codes can be cleared with unhooking the battery for some time.
Old Jul 1, 2008 | 12:28 PM
cgholson's Avatar
cgholson
Is this a black box that you're referring to which seats on top of a metal pipe that leads to the air filter?
Old Jul 1, 2008 | 05:37 PM
Och's Avatar
Och
You car should be able to run with both O2 and MAF disconnected. It would idle rought, but once you give it some throttle, it should be just fine. I think you might have a broken ECU.
Old Jul 17, 2008 | 05:35 PM
cgholson's Avatar
cgholson
Tried disconnecting the 02 sensor and MAF and I still have the same problem.
Old Jul 17, 2008 | 08:00 PM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
are you sure both banks are running right...?
have you checked for fuel and spark....
Russelltw
May 9, 2013 06:46 PM
ShiftyD2k
Feb 24, 2012 07:49 PM
palaka
RX - 1st Gen (1999-2003)
May 23, 2008 05:39 PM
palaka
Sep 3, 2007 06:58 PM
GoldieLex
Maintenance
Aug 8, 2005 09:28 PM
