Need help with fuses ASAP pls.
Old Dec 11, 2001 | 07:42 PM
retrodrive's Avatar
retrodrive
Search Function Inc.
Default Need help with fuses ASAP pls.
I was messing around with my dome lights and it looks like I've blown some fuse. I have checked every single fuse under the dash and under the hood. I found a blown one and replaced it. However I still get the same problem. Here are the symptoms:
Dome lights won't work, power locks are dead, power steering wheel colomn is not working, trunk does not open.
What else could it be. PLease help ASAP
Old Dec 11, 2001 | 09:47 PM
petrojeff's Avatar
petrojeff
It is the dome fuse 15A I think in the fuse box under the hood. This happened to me last week. All of the things that you said were out, were out with mine also. If you replace it and you still have the symptoms, it means you did something and created a short in the dome light system., when you were working on it. When I replaced the fuse , everything started working fine.
Old Dec 12, 2001 | 12:51 AM
retrodrive's Avatar
retrodrive
Thx a bunch, I will try it again tomorrow! I remember that I did short something out for a second...its all good now though.
JSlaughta
GS - 1st Gen (1993-1997)
Apr 26, 2013 08:14 PM
jdsethi
Dec 23, 2012 01:07 PM
Gplex1987
Jul 16, 2012 02:35 AM
bizzness
May 16, 2011 11:32 PM
retrodrive
Dec 14, 2001 01:25 AM
