Starter Replaced-now A/C Not Cooling
Old Apr 5, 2007 | 09:00 PM
swiggins's Avatar
swiggins
Red face Starter Replaced-now A/C Not Cooling
I just finished replacing the starter in my 91 LS-400, 156,000 miles; while I was driving around I tried the A/C. It never began to cool, so back in the driveway
I can tell that the magnetic clutch is not pulling in. My question is did I fail to reconnect the compressor when I put every thing back togeather? It's hard to tell with everything buttoned up if there is a connector under the intake that leads to the commpressor. I would be greatful for any thoughts before I start to take the intake back off.
Thanks
Sam
Old Apr 11, 2007 | 09:39 AM
swiggins's Avatar
swiggins
I found that the wiring for the compressor doesn’t run under the intake. I did find a burned out fuse on the A/C. I had given the fuse a visual inspection and thought it was OK. My multimeter proved otherwise.
I found the starter replacement to be time consuming and tedious. On this 16 year old car all the plastic is very brittle and easy to break. I think I could it much faster the second time.
Sam
Gamedina79
May 30, 2014 01:07 PM
SCLexxxy
Dec 13, 2009 11:39 PM
92lexus
Maintenance
Jul 23, 2008 01:23 PM
thailegend
Apr 2, 2006 10:24 PM
Evillex
Apr 25, 2004 09:39 AM
