What's wrong with my car? (chk engine & trac light)
Old 11-08-06, 12:28 AM
HKS_IS300
HKS_IS300's Avatar
Default What's wrong with my car? (chk engine & trac light)
i turned on my car today and the check engine light came on and the trac off light came off. i was wondering if i could narrow down the problem. any help would be much appreciated. thanks!
Old 11-08-06, 03:18 AM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Will since you dont want to tell us the year, and miles, the only thing I can tell you is to use the search function.
Old 11-08-06, 12:10 PM
HKS_IS300
HKS_IS300's Avatar
my car is a 91 w/ 209k
Old 11-08-06, 12:12 PM
lorenzo816
lorenzo816's Avatar
TROUBLECODES
Old 11-09-06, 09:59 AM
lp_yang
lp_yang's Avatar
i have the same problem now too......still aint figure it out....
Old 11-09-06, 02:45 PM
HKS_IS300
HKS_IS300's Avatar
what's weird is that it went away.....i still want to get it diagnosed tho
Old 11-10-06, 01:22 PM
persian451
persian451's Avatar
most likely O2 sensors. do the self diagnosis using a paper clip. cant remember which pins again, but do a search. The flashing codes on the speed cluster will tell you which sensor.
Old 11-11-06, 08:34 PM
justfixit
justfixit's Avatar
Look under hood for the Diagnostic Connector located on front driver side of engine. Jump terminals E1 - TE1. If you look under the cap of connector it will diagram terminal locations.
If light comes on and off frequently it is most likely code 25 or 71.
Code 25 is Oxygen sensor but you will have to diagnose which one. You will need voltmeter, set to check volts, one lead to E1 and the other lead to
OX1 (bank #1) and then OX2 (bank #2). If you rev engine quickly and let off you should have a reading of .1 to .9 volts and it should change constantly. If you dont see any voltage change then that is the defective sensor.
Code 71 is for insufficient EGR gas temp. Usually this is due to leaking vacuum modulator for EGR or EGR passages clogged.
Good luck
Jdwright
10-22-11 03:14 PM
rob328
06-04-11 09:07 PM
mccube
SC- 1st Gen (1992-2000)
07-11-07 11:37 PM
Jasoneo5
03-06-04 02:55 PM
healerhand
06-13-02 04:30 PM
Quick Reply: What's wrong with my car? (chk engine & trac light)
