LS400 intake problem
Old Sep 5, 2005 | 09:03 AM
playa3uhh's Avatar
playa3uhh
Default LS400 intake problem
I just changed the air filter in my car to an air filter cone with adapter, etc. But since the change, my car is showing hesitation when i shift. It keeps kicking back and it's annoying me. When I changed the filter, the plug that connects to the silver electronic filter piece, the car doesn't start. When I disconnect it, it does work. And now my check engine light is on because I disconnected the plug. Does anyone know what I can do or what the problem might be? Anything would help. Thanks guys!
1994 LEXUS LS400
105K miles
Old Sep 5, 2005 | 10:34 AM
RA40's Avatar
RA40
Reconnect the wire and then remove the fuses to the EFI pooter for 30 seconds or so. This will default back to factory settings. If the CEL is still on after this, remove the fuses to the main ECU for a minute.
Old Sep 5, 2005 | 12:05 PM
playa3uhh's Avatar
playa3uhh
Thank you for the help! But where will I find the fuses to the EFI pooter? Please let me know...Thanks!
--John
Old Sep 5, 2005 | 03:34 PM
GRAND_LS 4's Avatar
GRAND_LS 4
3UZ-FEEEE
the CEL will go away shortly, just make all the connctions are tight, and the box and screws are secured.
turbo556
Oct 6, 2011 07:51 PM
saustin
15
Dec 3, 2006 08:51 PM
91LS400vgb
Jul 27, 2006 05:26 AM
