96' throwing p1600 code
Old Jan 27, 2026 | 11:54 AM
ls400enthusiast's Avatar
ls400enthusiast
1st Gear
Question 96' throwing p1600 code
I don't know what the issue is. Fuses are fine and battery volt is fine. My next step is to check the ecu so I was wondering because I have another LS that's a 95'. I looked up if they are capable and didn't find much just a maybe so I'm here trying to make sure I could before I swap em out.
Old Jan 27, 2026 | 12:04 PM
Go to this thread
https://www.clublexus.com/forums/ls-...capacitor.html
Search for p1600
Or just pull the ECU and open it up to inspect, no use trying to chase down problems without knowing if the ECU is healthy or not.
Old Jan 28, 2026 | 07:15 AM
CELSI0R's Avatar
CELSI0R
In terms of being able to swap the ECU from your 1995 LS into your 1996, it's not straightforward
It depends on the part numbers of both. You'll need to do some more research
It also depends if both cars have Federal standard ECUs or California specific ECUs, as they function differently
One thread for reference, I suggest you do more searching and reading:
https://www.clublexus.com/forums/ls-...995-ls400.html
chrispap
Jan 18, 2026 11:18 AM
Zlike505
Nov 28, 2019 05:21 PM
Bocatrip
Oct 26, 2019 07:28 AM
jhuang2668
Jun 24, 2010 08:54 AM
3UZTaco
May 4, 2008 07:00 AM
