1992 Lexus LS400 Front driver seat belt retracting problem
Hello. I own a 1992 Lexus LS400 and my front driver side seatbelt is super loose. It isn't retracting at all. Belt is clean. Pulled the belt out completely and still won't retract. Any helpful information in fixing this problem will be grateful. Thank you
Sounds to me like the retracting spring has fatigued and isn't strong enough to pull the belt anymore. My 99 LS400, as well as my previous 03 Avalon, had a similar issue. I don't believe there's a fix other than replacing the seat belt unit with one that works, although I'm not sure if anyone's disassembled these old units to see if the spring can be replaced.
If it is retracting slow and not enough and retracts better when unbuckled vs buckled, your model year may have a tension reducer that you can unplug, that is the case in my 1995 and I have the tension reducers unplugged on both sides. It is a white plug near the tensioning mechanism. However, that may be specific to 95/96
pacerdonfl
Jan 25, 2017 10:00 AM
sleigh911
Apr 30, 2015 01:49 PM
DonCorleone
Jan 13, 2015 03:27 PM
