95 LS400 window not working
The window in my 95 ls400 wont go up or down the arm seems to of snapped off or somehow disconnected from the window itself I have the door card off right now, if anybody has any pictures of how its supposed to be connected or any advice on what to do or how to reconnect a new window arm/regulator that would be greatly appreciated. The regulator and motor works fine it goes up and down
just without the window connected to it.
I cant get your file to load? But your best bet is to pull the door panel off the opposite side door am you can look at how the is installed there. Its most likely that you need to get a new window regulator. The best option is a wrecking yard, but any parts store can get you one. The regulator is basically the hardware that the window motor uses to control the window when it goes up and down. And its common for them to wear out.
