p1346
Old Aug 6, 2025 | 08:17 AM
NetG's Avatar
NetG
Default p1346
2000 ls400, stock except for a deletion of the back two mufflers, front two still in place. 171k miles
my cats are bad but recently, after replacing my old battery with a neverstart, I’m now getting a p1346. then
the engine idles rough. I have a scanner and immediately after clearing the code it idles fine.
tbelt isn’t due but I don’t know if the previous owner changed the plugs. before the neverstart I had the cat code but it never gave the vvt code. it also displays “check vsc” which also goes off after clearing the codes.
I saw a thread saying this was usually caused by a bad battery but my old battery needed to be jumped everytime I started which is why I replaced it but it never gave the p1346.
obviously I need to address the cat code but the vvt and rough idle are more concerning so I want to focus my finances there. I haven’t had the battery checked, I plan to clean the maf with throttle body cleaner and replace the spark plugs (she still pulls well so not convinced that’s an issue)
any other thoughts?
Old Aug 7, 2025 | 07:27 AM
timmy0tool's Avatar
timmy0tool
i would start with the VVTi oil control valves. start with a clean, then if still persistent it might need complete replacement.
https://www.clublexus.com/forums/ls-...-ls-400-a.html
https://www.clublexus.com/forums/ls-...349-p1346.html
the check VSC is just a companion to the CEL. it goes away once the codes are removed (assuming the issues with the codes are fully resolved as to not return the CEL again).
Old Aug 9, 2025 | 05:18 AM
TrueGS300's Avatar
TrueGS300
I'd start by using an engine flush and de-sludging the engine. The cam solendoids usually just get gummed up. But they can be removed and cleaned too. You will also need to scrub out the throttle because each time your battery dies or is disconnected or replaced, the computer loses saved throttle position memory. You'll have terrible idle quality until it's cleaned out like new.
orZift
GX - 2nd Gen (2010-2023)
Feb 12, 2023 05:19 PM
x52
Hybrid Technology
Nov 25, 2019 08:50 AM
okiegx
GX - 1st Gen (2003-2009)
Dec 5, 2016 05:43 PM
NoUltimatu
May 14, 2015 05:09 PM
Benjamin T
Performance
Jan 22, 2007 08:22 AM
