Drivers low beam - no power to socket
Old Mar 14, 2025 | 11:00 AM
TominPT's Avatar
TominPT
Default Drivers low beam - no power to socket
I am getting about 0.03 V at the low beam socket for the drivers side low beam light when I turn on the headlights, should be 12V. The 15 A fuse for the light is good. The high beams work. The passenger low beam works. When I turn the lights on I hear an audible click which seems to be coming from the headlight relay in the engine compartment fuse block, and I get 12V at the low beam fuses.
What am I missing? Could the relay still be faulty if the passenger light comes on but the drivers does not? I have the correct bulb in the socket - it was working 2 days ago. Now no power. Need help.
Old Mar 15, 2025 | 04:09 AM
CELSI0R's Avatar
CELSI0R
Sounds like you have a wiring issue. Check the wires coming from the headlight and see if visually you have any breaks.
Does the socket have any corrosion?
Also, what year is your car again?
Old Mar 15, 2025 | 05:18 AM
TominPT's Avatar
TominPT
I am leaning towards a loose or broken wire as you suggest, and will be pursueing that angle. My car is a '98. No corrosion in the socket or at the relay. The wires behind the socket show the same voltage as the pins in the socket so the socket seems to be good.
KaptainKen
Jun 6, 2023 09:26 PM
chacha13
Mar 19, 2023 08:50 PM
ksigmon
May 8, 2019 09:20 AM
M45owner
RX - 1st Gen (1999-2003)
Nov 18, 2013 06:46 AM
kmn5
Jan 31, 2003 06:39 PM
