I have a 1995 LS400 Australian RHD Car.
The Capacitors behind the Speedometer and Tachometer are either Burnt, Deformed or stuffed.
I cannot read the markings on any of them.
Does anyone have the list of Capacitors and there values, there a three on each,
Thanks in advance.
These are not the Capacitors on the main Board. Image for reference.
Just an update on the Speedo and Tach Capacitors for the 1995 LS400
With the help of a good microscope we have identified some of the Capacitors. There is still one we cant read.
2.2uf 50V
4.7uf 35V
22uf 25V
Can anyone confirm if this is correct and confirm what the other capacitor values may be.
Physical size and 12v is unlikely to help. Capacitor technology has changed since the 90’s. A modern cap could be any size. And the voltage it operates on depends on the capacitance needed. I’d wait till someone with a working example can confirm values.
UPDATE: The Capacitors have been received and replaced on the Speedo and Tach.
Next issue before i return the cluster to the Car, does any one know how to Bench Test the back lighting for the needles and gauges.
Remembering this is a 1995 model. I found a "how to" for the 90-93 but nothing for 95-97.
Thanks
