limp mode??
Old Nov 21, 2024 | 06:38 PM
pslxcybn's Avatar
pslxcybn
10th Gear
Default limp mode??
hey guys so i have a 1993 lexus ls400 and earlier i was driving like normal and i got to where i needed to so i turned off my car and a couple minutes later i turned it back on because i was gonna move and when i turned it on it revved up to around 1.5k rpm and i was like what the so i checked my throttle cable because ive had an issue where it got stuck open so i thought it was that but it wasn’t so i was kinda stumped
so i went to turn it on again and it made some sort of weird noise im sure and i thought it had sucked something into the intake so i checked all that and everything seemed to be fine so i didn’t really know what was wrong with it and i reversed out but when i put it in drive it didnt wanna move at all so i gave it gas to around 2.5k and it barely started moving
so i parked again and tried to a diagnosis with a paper clip since these don’t have obd2 yet and my CEL wasn’t flashing the way it should and i’ve done it before so i know it works but this time it didn’t so i tried the inside and the one in the engine but no flashing nothing.
so i talked to my homies to see if they would know and one said to disconnect my maf sensor and see if it doesn’t anything so i did that then turned it on and it still idled really bad (around 500rpm) so then i pulled 3 spark plugs and they all had black tips and some oil around the threads but does anyone know what could maybe be the issue or anything i should check??
Last edited by timmy0tool; Nov 22, 2024 at 10:21 AM. Reason: added carriage returns for easier reading - OP likely wrote this on their phone
Old Nov 22, 2024 | 10:25 AM
timmy0tool's Avatar
timmy0tool
this could be many things but most likely it's this:
https://www.clublexus.com/forums/ls-...capacitor.html
signinffs
Apr 29, 2024 04:29 PM
TrippieKitty666
16
Jun 22, 2023 04:01 PM
malgus270
Jan 9, 2016 05:20 AM
AyoChriss
Jun 9, 2011 10:26 AM
hiephopp
May 5, 2009 08:56 PM
