Diagnosis Help
Old Nov 16, 2024 | 09:07 AM
ucfjason's Avatar
ucfjason
7th Gear
Default Diagnosis Help
I just replaced my alternator (autozone alternator)
The car starts right up however when i rev high 3-4k rpm, the ABS, VSC, and battery light come on. I checked the serpentine belt, fits correctly.
When I let off the battery light turns off however abs and vsc stay on. The lights only come on after revving.
Old Nov 16, 2024 | 02:52 PM
TominPT's Avatar
TominPT
I would suspect the alternator. When the battery light comes on that normally means the battery is not being charged by the alternator. If that is correct, use a Denso OEM or rebuilt OEM alternator, I would also scan for any codes causing the ABS and VSC lights to come on.
Old Nov 16, 2024 | 02:59 PM
400fanboy's Avatar
400fanboy
Lots of problem stories with aftermarket alternators in this car. Why did you replace the alternator in the first place? Just curious.
Old Nov 17, 2024 | 01:05 PM
ucfjason's Avatar
ucfjason
7th Gear
https://www.youtube.com/watch?v=LGB6ZEjGm7Q
Car would die after jumping every single time, would pull the key out and all the lights out.
Old Nov 17, 2024 | 02:28 PM
ucfjason's Avatar
ucfjason
7th Gear
Update* Just tested the alternator, Voltage regulator is definitely the problem, when revving the car, Volts jump to 18. Should I replace the alternator altogether or try to replace the voltage regulator
Old Nov 17, 2024 | 07:09 PM
paulo57509's Avatar
paulo57509
Replace the alternator. The voltage regulator is inside it.
Get a replacement from AZ. It should be under warranty. Expect them to test it and give you flack.
bbmach
Apr 14, 2023 12:57 PM
lottadik
May 17, 2019 12:07 PM
Forrestb
Jul 19, 2016 05:15 PM
Echo419
Jul 29, 2014 08:35 AM
Gunnut
Oct 22, 2011 05:54 PM
