1998 Engine ECU bricked
Old Apr 25, 2024 | 07:23 PM
bbkadn's Avatar
bbkadn
10th Gear
Default 1998 Engine ECU bricked
Hi, first things first, english is not my first language. Please don't get too hard on me.
I confused the engine and abs plugs and bricked the engine ecu. Fuses from ign and starter popping off.
I got an LHD EUDM model. Does anyone knows if could use UK EUDM ECU?!
@Yamae MAYBE?
Old Apr 25, 2024 | 07:45 PM
Yamae's Avatar
Yamae
Sorry that I have no idea to answer your question. Even if it's OK to use the UK one, the immobilizer issue will be there.
What are the current symptoms and the error codes? You need to use a code scanner which can handle Toyota K-Line bus protocol system though. Non North American models are not fully compatible with the OBD2 system. Those use almost the same error codes but the communication protocol is different and the American OBD2 scanner is useless.
Old Apr 26, 2024 | 02:11 AM
bbkadn's Avatar
bbkadn
10th Gear
I got techstream but didn't tried yet to scan codes. It could damage my laptop.
Immobilizer is not a problem. I got a full spare car.
Couldn't find any wiring diagrams and I'm not sure if i should just try. Don't wanna brick another ecu even when it's connected correctly😅
Ken167
Feb 13, 2024 07:31 PM
Soldat79
Jan 23, 2022 06:52 AM
Aus430
Feb 5, 2019 02:00 PM
LexBrett
Apr 14, 2015 06:30 AM
Red93sc400
Jan 13, 2002 08:20 PM
