Ls 400 code 25
Old Apr 3, 2024 | 07:34 AM
mihalichew's Avatar
mihalichew
7th Gear
Default Ls 400 code 25
Just got ls 400 1992 with 162k miles and check engine light came on shows code 25 and TRAC OFF I changed the down stream O2 sensor and nothing change I heard that it could be the MAF SENSOR or The UPstream O2 sensor any suggestions ?
Old Apr 3, 2024 | 12:01 PM
timmy0tool's Avatar
timmy0tool
http://www.lexls.com/tutorials/intro/codereading.html
25 - Air-fuel ratio lean malfunction
it could be many issues and throwing parts at it is expensive, but i think you're on the right track with the o2 sensors. however the car has 2 downstream sensors, and 2 upstream as well so which one is it?
which one did you replace so far? since you have a new one, swap it to the other side. you cannot use a downstream sensor upstream and vice versa, but you can swap left to right.
Old Apr 3, 2024 | 10:08 PM
mihalichew's Avatar
mihalichew
7th Gear
and forgot to add that when starting the car rpms are around 800 900 and when warming up and rpm goes down, the car wobbles like it is going to stow but then around 400 rpm it becomes stable but time to time it shakes a bit
Old Apr 4, 2024 | 09:54 AM
CELSI0R's Avatar
CELSI0R
There is a simple test you can do for Code 25 to test your upstream o2 sensors with a multimeter
I posted about this in February
https://www.clublexus.com/forums/ls-...l#post11675188
My car got code 25 a little over a year ago. I found my left bank upstream o2 was lazy after the test
Alraeesi
Jul 20, 2024 06:35 PM
xewuu
Jul 10, 2024 05:46 AM
ONashir
Aug 30, 2022 01:34 AM
saelee39
Jan 24, 2010 09:33 PM
rsos1
Dec 17, 2007 02:21 PM
