Downstream O2 Sensor Replacement
Old Dec 26, 2023 | 07:18 PM
e30antonio's Avatar
e30antonio
Default Downstream O2 Sensor Replacement
Hi all,
I have a P0136 "heated oxygen sensor 2, bank 1" code on my 2000 LS400. A couple questions:
1. Sensor 2 Bank 1 is the driver's side downstream sensor, correct?
2. To replace it, am I able to cut the old O2 sensor off and splice in the new sensor to avoid tearing apart the interior carpet?
Thanks!
Old Dec 27, 2023 | 08:30 AM
CELSI0R's Avatar
CELSI0R
1) Yes, Sensor 2 Bank 1 is the Left/Driver's side (in the US) downstream O2 Sensor
See this post for documentation:
https://www.clublexus.com/forums/per...ml#post2486474
2) Sure, that's possible as long as you insulate the wires properly. Ideally with a couple of layers of heat shrink or tightly wound electrical tape after you solder the wires together. It's ideal to disassemble and use the connector of course
Leederosa
Dec 16, 2023 01:06 AM
hummingbir
May 26, 2022 10:23 AM
SICK350
Mar 11, 2014 05:20 PM
ADENNARD
May 21, 2013 06:27 AM
swat1727
Oct 1, 2008 11:50 AM
