2000 LS400 Serpentine belt shredding
2nd gear
I've replaced it twice with two different brands, but something is causing it to shred the sides of the belt. Do I need to adjust a pulley? Do I need to replace something? Please help thank you
It looks like something might be causing it to get pushed off the pulleys causing it to get frayed.
One of the pulleys is not straight you should be able to eye which one.
http://www.japan-parts.eu/lexus/us/2...601_water-pump
Gummy7748 (09-01-23)
Q: Are you positioning the belt on the pulleys properly on installation? Your image shows the belt isn't on the outermost rib on the pulley. Or is this happening after the belt is run for a while?
2nd gear
As mentioned, pulley inspection.
Just curious - why was the belt replaced in the first place?
e30antonio
10-18-19 12:25 AM
Finucf10
01-24-18 12:22 PM
d1drift
12-05-06 08:03 AM
