Banjo Bolt on Power Steering Pump HELP
Old Mar 23, 2023 | 03:48 PM
Tappy's Avatar
Tappy
Default Banjo Bolt on Power Steering Pump HELP
I am close to getting the power steering pump off of my 1999 LS400. But, the damn Banjo Bolt on the PS pump is an hard to come off. I feel like the last person to work on it over torqued it.
Is there something I need to do to remove this banjo bolt? Or do I just need to reallllllly put some muscle into loosening it?
Old Mar 23, 2023 | 04:03 PM
Sharp impact is best, if possible. Hammer against wrench etc. Dumb question, you are turning it the correct way, yes?
Old Mar 23, 2023 | 04:12 PM
Tappy's Avatar
Tappy
Lefty loosy righty tighty?
Old Mar 23, 2023 | 04:16 PM
Sure, but depends on perspective.
Old Mar 23, 2023 | 04:30 PM
Tappy's Avatar
Tappy
Idk how I would fit an impact gun in there
Old Mar 23, 2023 | 04:39 PM
A small air impact might fit, probably not. Put a ratchet on that, hammer time. Or a ratchet with a long pipe it will yield. Force the pipe with the quickest, sharp motion you can. Why are you trying to get the banjo loose?
Old Mar 23, 2023 | 04:41 PM
Tappy's Avatar
Tappy
I’m trying to remove the banjo bolt to remove the power steering pump. I’m considering remove the high pressure line altogether now…..
Old Mar 23, 2023 | 04:51 PM
If you're not getting anywhere then yea go that route. If practical of course.
Old Mar 23, 2023 | 06:21 PM
bradland's Avatar
bradland
1/2" drive breaker bar should make quick work of that. You may have to do it from underneath tho...
Old Mar 23, 2023 | 06:54 PM
Tappy's Avatar
Tappy
I got it out with help! Thank goodness. Used two wrenches. Anyone happen to know the part number for a banjo bolt?
Old Mar 23, 2023 | 07:03 PM
I have it memorized (no I don't)
http://www.japan-parts.eu/lexus/us/1...-steering-tube
click numbers to get full part number(s)
Old Mar 23, 2023 | 07:15 PM
Tappy's Avatar
Tappy
Thanks! I was also looking for the two 14mm bolts that secure the power steering from under the car. I don’t think I see those in the diagram. Would you also happen to know it?
Old Mar 23, 2023 | 07:33 PM
Vane pump details are here
http://www.japan-parts.eu/lexus/us/1...power-steering
Or if not poke around the diagrams you'll find them.
Old Mar 24, 2023 | 12:18 PM
paulo57509's Avatar
paulo57509
Banjo Bolt = 9634141603
Seal Washers (2ea) = 4432730030
Old Apr 9, 2023 | 08:21 PM
Tappy's Avatar
Tappy
The part number for the two bolts that secure the power steering pump up onto the motor are: Bolt Flange = 9151261040 .
