2010-2013 OEM Radio, Stereo, Navigation Problems, Questions, Updates
#241
Super Moderator
So the LS 460 (not sure of other models) with ML had option to record audio to HD until 2010? I believe there was some legal issue to remove this feature at or after 2010 model year. That was the case with Nissan anyway. It appears from 460 FSM there were plans to release feature but got yanked.
#243
Super Moderator
Here is additional info on firmware updates to 10-13 models.
https://www.clublexus.com/forums/gx-...re-update.html
This hacks remain to be seen
https://www.clublexus.com/forums/gx-...13-models.html
#244
lexus gx 460 gps
hello, I have a lexus gx460 2010, when I put the gps it works well only that it is not heard by the speakers of the car, it is that normal. Thank you
#245
lexus gx 460 gps
#247
Gracias 460 2010 gps
hello everyone, I have a lexus gx460 2010. the gps works well, but I can not hear when he speaks, this gps is like this or there is something wrong
#248
Super Moderator
If you have confirmed GPS sounds settings are enabled... it might be problem with this multimedia ECU
#249
If confirmed that this option is turned on, I have only heard of this once here.
https://www.clublexus.com/forums/gx-...t-working.html
#250
Updating back up camera on 2011 GX
Is there anyway to update the back up camera to add the parking lines or even the bending lines that minor the steering wheel direction. I drove a new RX last week because my SUV was in for an oil change. Wow what a difference!!
#251
Unlikely. Also costs prevented to upgrade. The fixed (and/or dynamic moving) guide lines are part of Center display and Park Assist ECU functions, especially the moving dynamic lines also interactive with steering spiral sensor as well. Based on my recent findings, the later GX model (2014+) fixed guide line (the blue and red) are build into the display unit and suer imposed on reverse camera image. The dynamic (yellow) moving guide lines are generated from Park Assist ECU which only available with certain configuration and equipped GX, particularly in oversea market.
#252
Even new 2018 GX's only get the dynamic lines if the optional "ZA" Driver Support Package w/Mark Levinson Audio, Pre-Collision System w/Driver Attention Monitor, Dynamic Radar Cruise Control, Lane Departure Alert, Intelligent High-Beam Headlamps, Wide-view Front and Side Monitor, Crawl Control is ordered.
#253
The cameras Ive used had the lines built in the camera. You cut a wire to remove the lines. These are the fixed lines, not the dynamic ones. make sure you get or modify for the proper voltage if you are going to use the same power source as original.
#255
If you use the lines to get the vehicle parallel with the parking stripes, then very useful.
