Sponsored by: CARiD
those with retrofits
Old May 3, 2003 | 10:57 PM
Jmai22's Avatar
Jmai22
Default those with retrofits
i finally picked up the stock ring that goes around the stock projector today to put around my retrofit. The ring that went around the stock projector doesn't fit around my 5 series projector. I was wondering how you ES and other guys that did the retro yourself got the ring to fit. i found that my ring was about 1/4 or so of an inch too small. I attached a picture of the ring that i made that i have been using to show you guys what i'm talking about. i want to put the stock ring in because it looks much better but it won't fit. Thanks
Old May 4, 2003 | 01:47 AM
tiguy99's Avatar
tiguy99
Well...the ES ring actually is a little different from the GS one. I know for my car I used E46 3 series projectors which are smaller than the factory projectors so the fit was fine. In fact the ring is part of a special unit which has both the high beams and the low beams attached to one piece of steel. This steel contained the actual cut offs and made things easy to do the job. (Just in case we're refering to the same thing, I've attached some pics to help us get on the same page.)
Old May 4, 2003 | 01:45 PM
squarehat's Avatar
squarehat
Tiguy, did you get the front bezels to hide the gap between the edge of the projector lens and the the cylinder/ring in which the projector is mounted? I love how the E46 bezels have "X E N O N" embossed into them.
Old May 4, 2003 | 02:51 PM
Kyle Harty's Avatar
Kyle Harty
John,
I had to hack up the factory rings to get the projectors in, so the rings are partially there; here's a couple pics so you can see what I'm talking about. They basically cover the gaps between the legs on the BMW projector, with slots cut for the legs to go through.
I had to cut and grind out the cutoff and glare shield you saw in Tiguy's pics, and then cut about 1/4" off the back of the ring and cut the slots into it so I could slide the projector in. I hadn't counted on having to cut the slots but I was past the point of turning back and was gonna make it work if it was at all possible. I'm glad I didn't give up, I love the lights, it'd be tough to go back to halogen. It'd never occured to me until I was reading this post, I might try putting the little ring that holds the stock lens in place back on to fill that little gap I've got. I'm not sure how it'd look since the lens sits a little farther back and it wouldn't be flush but I'll have to take a closer look at things and see how that might look. I think I cut off at least one of the holes they mounted to, but a little glue could solve that problem. I like those BMW bezels that say Xenon on them too, I remember that 2nd generation GS with the retrofit using those, looked very nice.
I hope that helps answer your questions.
Old May 4, 2003 | 04:16 PM
siniquezu's Avatar
siniquezu
I can't mount the E39 projector on SCs like you did Kyle. The mounting screws will be copletely messed up. =(
I think I'm gonna have to make a custom ring too. Anyone think using aluminum would be a good idea?
Old May 4, 2003 | 11:10 PM
tiguy99's Avatar
tiguy99
No I didn't get the front bezels off the 3 series because when you close the headlight up, they wouldn't fit. Our ES300 headlamps have chrome metal covers already. Check out these pics to see what I'm talking about...
1. my headlamp during the day
https://www.clublexus.com/gallery/sh...t=1&thecat=506
Kyle's headlamp during the day
http://images.cardomain.com/member_i...68_27_full.jpg
2. Below is a picture the actual covers and projectors. Putting them on is pointless because it would involve cutting it and grinding it down to size just to make it fit. The size would be like 1.5 to 2 cenimeters. They cost like 60 bucks and are not cost effective to have on there at all.
Old May 9, 2003 | 10:27 PM
siniquezu's Avatar
siniquezu
I tested my projectors (on an SC) and there is just enough space between the headlight plastic and the projectors to glare. I'm going to go and get a sheet of aluminum from home depot and make a thin ring of aluminum to cutoff any light coming through this gap. I'm not sure if this will work but if you guys have any other input, I'd be glad to hear it.
A strange aspect is that I also get glare through the clear lens that lets you see the adjusting bubble!
khoi714
Oct 1, 2018 07:50 PM
RacingLuxury
Feb 25, 2008 01:50 PM
3rdelement
Lighting
Oct 21, 2005 06:49 PM
ILOVEGIRLS
Lighting
Jun 8, 2004 11:26 PM
BabaBooey
Mar 19, 2002 10:22 AM
