Sponsored by: CARiD
Help Installing RAZO bulbs
Old Mar 25, 2003 | 04:17 PM
RNM GS3's Avatar
RNM GS3
Default Help Installing RAZO bulbs
Im replacing the low beam headlight bulbs on my car with RAZO bulbs. The problem is when i try to place the bulb in the housing and screw it in to tighten it, it doesnt go in. I tried doing this with the OEM bulb and it screws in easily. Any ideas what the problem could be???
Please help, thanks.
Old Mar 25, 2003 | 04:30 PM
EXE.UCF10's Avatar
EXE.UCF10
VIP|EXEstyle セルシオ
Are you sure it's the right sized bulb?
Old Mar 25, 2003 | 05:57 PM
RNM GS3's Avatar
RNM GS3
ye the bulb is 9006. the bulb itself fits fine. its the round plastic thing at the bottom of the bulb that u have to screw into the housing in order to keep it in place, it doesnt seem to fit. I have no idea why because it looks exactly like the OEM one.
Old Mar 25, 2003 | 07:10 PM
rominl's Avatar
rominl
exclusive matchup
so you mean you can push the bulb in already (meaning the 3 ***** are aligned correctly) but it doesn't turn? push in harder and turn. the rubber ring is for water proof
Old Mar 25, 2003 | 07:18 PM
RNM GS3's Avatar
RNM GS3
Rominl,
The 3 pieces are not aligning for some reason, thats the problem. I tried different ways to get them to align and then push it in and turn it, so far no luck. When i put the stock bulb back on in it aligned perfectly and went in no problem. I will try again tomorrow.
Old Mar 25, 2003 | 08:45 PM
rominl's Avatar
rominl
exclusive matchup
Originally posted by RNM GS3
Rominl,
umm..... try again in sunlight or with a flashlight. there must be one orientation where all 3 ***** align and fits in. try to jiggle around a bit too
gcam77
GX - 1st Gen (2003-2009)
Jul 11, 2018 08:07 AM
ThermonMer
Nov 12, 2011 01:29 PM
ocwescoast
Nov 28, 2007 06:59 PM
ArmyofOne
Lighting
Mar 23, 2005 08:49 PM
