Sponsored by: CARiD
Need Help HID 1999 ES300...
Old Jun 8, 2010 | 03:51 PM
cellomac's Avatar
cellomac
Default Need Help HID 1999 ES300...
I am going to install HID's on my 1999 es300. I got drunk and thought it was a good idea to just buy a kit without doing my research first. I bought a low beam only h7 kit 55 watts 6000. Now I have a few questions:
1. Did I buy the right kit for my car?
2. I been reading about relay's, Do I need one?
3. How bad is it to use HID's in a non HID assembly?
Any help would be greatly appreciated. I'm sure the installation part is a breeze, I just want to make sure everything is ok before I start. Thanks.
Old Jun 8, 2010 | 04:56 PM
alan003's Avatar
alan003
1. h7 is the right kit
2. relay harness is safer for your car
Old Jun 17, 2010 | 07:00 PM
cellomac's Avatar
cellomac
Finally got lights and got them all installed. Didn't get a relay, wanted to see how it worked without them first. Seems ok for now.
Next question: Where and how should I mount the ballasts? The sticky tape it came with doesn't hold very well and it did not come with mounting screws. I would like to use zip ties but can't figure out where to put them. Any help would be appreciated. Thanks!
PS: I got the DDM slim ballasts, If anyone has these, what size mounting screws do they take. I really don't want to take them back out and bring them to the store to find out.
Old Jul 12, 2010 | 09:27 PM
QuachmanES's Avatar
QuachmanES
CL Folding 25,000
I would definitely recommend getting a relay harness. With a relay, the ballast is getting power directly from the battery instead of through the stock headlight harness; especially if you are running a 55 watt kit, you may run into heat issues later on.
As far as mounting, I can't help you there. I got HIDeXtra kits, and they came with a mounting plate and screws.
Old Sep 29, 2010 | 06:20 PM
azscout's Avatar
azscout
Default Please share Pictures
I have a 99 ES300 where did you buy and how much thanks
funcrusher
Lighting
Nov 6, 2014 06:42 AM
mildawg
Dec 1, 2008 09:31 AM
SP Lex
25
Jan 14, 2008 05:12 PM
x2mkx
Lighting
Feb 13, 2006 11:42 PM
