mobile hid
i'm not fixated on the cheap $60 price as much as i'm trying to understand the true differences =)
also, the reason i'm askin about quality difference is because i plan on getting a 3000k fog kit, pair of 6000k bulbs (since i already have LS430 retrofit for more output) and another 5000k low beam kit for a bmw 3 series.
i rather order once and do it right... plz get back to me. thx!
When you pick up a mobilehid ballast. If you've played with HID balalasts before, the first thing you notice is the weight. They are noticeably heavier than just about ANY other ballast on the market. The reason why they're heavier is because there weren't any corners cut to compromise the integrity of the components inside and the solid exterior case that houses the electronics. Additionally, they are injected with a rubber compound to ensure the electronics do not come loose under constant or sudden vibration and to ensure they are absolutely waterproof. You can see a demonstration of this durability on the main mobilehid site:
( http://m.youtube.com/watch?v=KFlZZuk...ient=mv-google ) where a ballast is subjected to the most ridiculous stress test imagineable. In the video a ballast that was used for approximately 10,000 miles was taken out of service to undergo a beating with a hammer. The ballast was turned on and powering a light at the time and what's not mentioned in the video but should be noted is the fact that the video was the 3RD TAKE! The ballast already had sustained cosmetic damage from earlier beatings and you can see the dents in the case before the hammering starts.
It's this kind of quality construction that is used to produce a product that will continue to run long after other ballasts have failed when subjected to the same tests. Customers in the past have shared some crazy stories about these ballasts continuing to work under the most unlikely situations.
A past customer installed a set into his car and simply secured the ballasts with a couple of zipties on the shock towers of his car. He drove for a few weeks and reported that his lights were flickering every now and then but his old set from some other company did too so he didn't give it much thought and didn't report the issue. Turns out, when the ballast failed and he opened his hood, his ballast had slipped over to the engine and had been rubbing against a pulley which created a half inch deep gouge into the edge of the ballast. It still functioned while rubbing against the pulley even under intense heat caused by the friction and even after the exterior case was compromised.
Another story, this one from one of our members here, happened in Texas where a GS owner had a ballast fall out of his engine bay while driving. It was seen dragging on the pavement by other CL members while they were all driving. The ballast finally unclipped from the wires and got run over by the rear tires and subsequently other cars behind him before he had a chance to turn around to get it. Once he did, he connected it back into his car and it still worked.
So materials wise, the ballast is designed tonbe very stout. With regards to the kit as a whole, many other kits do not come with a relay harness and if you are going to get a kit, I suggest you look for one that comes with one to prevent the need for all your OEM electrical equipment that is being fed power to compete with your ballasts.
Hope that helps explain the advantages of the kit.
Thanks.
Clifford
that said, if it does fail, do you guys have any warranty by any chance?
i'll definitely be giving mobileHID some business... a part of me almost wanna try to order from each vendor and post a personal review later =)
Thanks.
Clifford
Regarding your want to purchase one kit from each vendor... lol - beat ya to it man!
Check out the not so complete review here:
http://www.mobilehid.com/philips-review.htm
Thanks.
Clifford
i instantly recognized the philips ballast. thats what was on my old kit that i paid $600 for... it served me good from 02-06 and then i sold it to PJ on this board who's probably still using it to this day...
final question. since i have the LS430 retrofit (but still has oem 4300k), if i want to upgrade the color for it, do i just buy the 9006 6000k bulb or do i buy the D2S 6000k bulb that you have listed for $60? I'm not sure what the difference in the two are.
also, would it be a disservice to the projector/retrofit if i had lessen the output but going w/ a more blue temperature?
Also, yep - DarkKnight is right - You're going to need a D2S bulb for those projector housings.
I saw a video of a mobileHID startup on a 2010 Prius. It had a teal flash before startup. So does that mean mobileHID ballasts do not soft startup?
I'm pretty sure the TL customer had an aftermarket stereo system where he was able to connect the ballasts to power without interfering with the OEM circuitry.
