Sponsored by: CARiD
one moe question
Old Aug 12, 2007 | 10:25 PM
huerdo623's Avatar
huerdo623
Default one moe question
If I get an hid conversion kit will it look good coming from my projectors or am I going to have to do a retrofit
Old Aug 12, 2007 | 11:04 PM
3000's Avatar
3000
If you have a 92-94. Yes it will look good. But aim it low so that you wont blind people on the road if you don't wanna do a retrofit. The cut off line wont be as sharp as retro fit but it's similar to the stock beam pattern.
Here's a pic of my 92 with plug and play. Notice the bleeding on the top of the beam. It's blue but it does not bleed as much as it happens on some cars.
Here, is another plug and play... This one gives off major glare that blinds people.
And this one is the retrofit. The one with the sharp cut off. I'd like this but I don't have the time and money to do a retrofit. One side headlight on only.
The retrofit will give you the best light output. My pic looks like little light output because I parked the car too close to the garage door compared to the 3rd pic.
The last two pictures are from intellexual.net.
Old Aug 13, 2007 | 01:02 AM
huerdo623's Avatar
huerdo623
i have the 92,I really want the good cutoff,but if retrofitting the tsx or s2000 projectors is hard then I'll skip it,
Plus,sorry guys and gals I forgot how to spell
Old Aug 20, 2007 | 03:02 AM
Shon.nv's Avatar
Shon.nv
retrofit is easy but time consuming. I have done about 5 retrofits so far and played with so many projectors. PM me if you need more help, I'll guide you through it step by step.
nwscoobie
Mar 17, 2015 09:49 AM
TheAzn
May 21, 2013 05:36 PM
datsetup
Lighting
15
Nov 30, 2005 03:18 PM
2jzsc3
Lighting
Apr 16, 2004 09:10 PM
jersey1
Lighting
Sep 25, 2003 02:21 PM
