Sponsored by: CARiD
DIY GS Retrofit Instructions
Old Apr 18, 2007 | 05:33 PM
URDONE's Avatar
URDONE
Originally Posted by GSoup
It's not hard to remove the bumper. I did it numerous times when i was working on my turbo.
There are 2 10mm screws on each side that are accessible through the wheel well. Unscrew the fogs, disconnect the bulbs. Then you have 2 screws near the headlights on each side and your almost done. Go underneath and pop off all the plastic bolts holding the cover underneath. I believe that was it. I'm going off of memory here.
Its not that hard takes about 15-20 mins tops. You do need a long ratchet extension though.
I also did the NON-HID to HID conversion, but I used heavy duty harness wires with relays to power the ballast. If you know basic wiring it should be a piece of cake.
Do you know where I can find directions on how to make a heavy duty harness, or at least buy one?
Old Apr 18, 2007 | 08:22 PM
dung0981's Avatar
dung0981
CL Folding 10,000
Mod this one a little bit, you should be fine
http://www.xenondepot.com/product.php?product_id=50
Dont install HID system with out the relay
GL
Old Apr 19, 2007 | 04:39 AM
URDONE's Avatar
URDONE
GL
What kind of modification do I need? And which option do I need? Sorry for all the noob questions.
Old Apr 20, 2007 | 12:50 AM
dung0981's Avatar
dung0981
CL Folding 10,000
You need mod the input of ballast. Thats all you need. everythings else just plug and play
Old Apr 20, 2007 | 04:04 AM
JeffTsai's Avatar
JeffTsai
Originally Posted by URDONE
Dumb question, but is there really a huge difference?
Yes of course there's a huge difference. I'll let the pictures talk
Old Apr 20, 2007 | 04:43 AM
URDONE's Avatar
URDONE
Are these HID reflectors or halogen reflectors you used here? That is what I was asking about. If it made a huge difference in using Halogen reflectors vs HID reflectors?
Old Apr 20, 2007 | 11:22 AM
dung0981's Avatar
dung0981
CL Folding 10,000
not HID reflectors, Projector ...nice cut off
Old Apr 21, 2007 | 04:52 AM
URDONE's Avatar
URDONE
I realized I am asking some real noob questions here. I think I was just confusing myself over cutting up the HID reflectors bowls vs the Halogen reflectors bowls for my retrofit. Thanks for your help guys.
I finally got my HID headlight assemblys in the mail yesterday . One of them came with a autoleveling module???? I know I can't use this feature on my NON HID car. Now I just really have to decide what projectors to get, and what bulbs to use.
What would you guys say would be some good projectors to use for my first retrofit? Should I just dive in and get the LS 430 projectors and hope I don't ruin them, or should I get something a little less expensive like the TSX projectors?
Mikera
Jun 24, 2023 11:54 PM
celimages
Apr 23, 2019 02:01 PM
krappy
May 5, 2009 09:14 AM
Rich27
Lighting
Mar 19, 2004 09:15 PM
ripe911
Lighting
Mar 11, 2004 12:32 PM
