gs retro fit wirring
iv tried searching but havent found much.....i want to retro fit the infinity headlights on my gs but i have no clue on how to wire everything cuz im sure its not a plug and play thing...thanks for any help...
does your GS come with halogen or HID?
if it comes with HID, then all you need to do is put in the projectors and you'll be done. Everything else is the same.
if you have halogen, you'll want to make a wire harness for the HID ballast.
So which one do you have?
Be sure to get the correct hid set. If you are using the halogen housing, you will need D2R, and if you will do a retro fit, with projectors you will need D2S.
PM me if you need some other help.
ILOVEGIRLS
Dec 14, 2007 04:05 PM
