Sponsored by: CARiD
Festoon LED bulb intermittent problem
Old Mar 6, 2006 | 08:03 PM
sputniknyc's Avatar
sputniknyc
Default Festoon LED bulb intermittent problem
FESTOON FESTOON FESTOON FESTOON FESTOON FESTOON
My festoon led bulb in my overhead would work when it wants to.
Would cold weather affect the bulb?
Seems like when I first get into the car the led would not work.
Old Mar 7, 2006 | 09:21 AM
PHML's Avatar
PHML
Master Thread Closer!!
Try squeezing the contact points closer together so the festoon bulb stays in place....maybe its just loose and not making contact.....or.....the LED has burnt out (it happens....believe me).
Pete
Old Mar 7, 2006 | 09:30 AM
sputniknyc's Avatar
sputniknyc
Pete
Oh it still works..Just that sometimes it will not work so I'm sure it is not burnt out. I will check the connections again.
Thanks
Old Mar 7, 2006 | 01:37 PM
khhoang's Avatar
khhoang
Check all the doors trigger buttons to make sure they're not sticking. The buttons are usually behind a rubber protective covering. Couple shots of WD40 should fix that.
Old Mar 7, 2006 | 10:29 PM
sputniknyc's Avatar
sputniknyc
Not the doors, The LED is not turning on when I flip the switch.
I have a feeling that the extreme cold weather would cause it.
Old Mar 9, 2006 | 05:31 PM
DASHOCKER's Avatar
DASHOCKER
I need to find that for the rear doors Where is it for the rear doors?
mswtoyota
GX - 1st Gen (2003-2009)
Dec 23, 2015 10:11 PM
VNN326
General Classifieds
Jan 31, 2011 02:45 AM
DaNiELx626
Lighting
Mar 18, 2010 12:33 AM
///MDex
Feb 21, 2002 05:46 PM
