Sponsored by: CARiD
any 92 LS400 hid kits?
Old Feb 7, 2006 | 11:05 PM
JdmLs400's Avatar
JdmLs400
Default any 92 LS400 hid kits?
are theere any kits for this model? and if so, which kind? cuz i have no sense in lighthing...
Old Feb 8, 2006 | 10:04 AM
EXE.UCF10's Avatar
EXE.UCF10
VIP|EXEstyle セルシオ
There are plenty, but stick with Philips or Hella. If whatever brand makes a 9004 (aka HB1) application, then it'll work for your LS.
Old Feb 8, 2006 | 01:20 PM
G Star's Avatar
G Star
Sorry to say but it's not about how much you know about lighting. It's only that you have no sense in searching. You do not let yourself learn this ability and it only hurts you in the long run.
Moral of the story : learn to search, it's good for you.
Example : If my catalytic converter started to sound bad. I would go on the advanced search engine and type in catalytic converter and choose the SC exhaust/engine/turbo sections. I would then use some common sense to find which thread best suited me based on its title. Next up, I'd start reading and keeping a sharp eye out for fellow members who have the same kinds of symptoms as I do. If the problem did end up to be a bad catalytic converter, I'd then continue reading the thread or find other threads that could help me decide to get different types of aftermarket high flow cats or stick to quality and reliable OEM catalytic converters.
I know it may be hard the first time but just try it out once or twice and it will get easier as you continue.
Old Feb 9, 2006 | 12:40 PM
Caoboy's Avatar
Caoboy
9004, mccullough, i got mine off ebay. its good, except i have one problem. after i installed it i believe it drew too much power, and blew the fuse on my foglamps. (i dont know why though, unless some of the other first gen LS guys remedied this let us know) right now the fog's arent working. im going to go check it out this weekend, what i found from searching on here, is that i need to change out the 15amp fuse to a 20 amp fuse, and the fogs should work again. thats what i found, no one else has a reliable solution to the problem.
96ls400ky
Oct 2, 2009 09:58 AM
93LSexy
Lighting
Jan 7, 2008 07:50 AM
fangtl
Lighting
Oct 13, 2006 06:59 PM
tcho82
Lighting
Sep 29, 2006 06:16 PM
nsg1000
Lighting
Feb 6, 2004 09:50 AM
