Sponsored by: CARiD
Brighter HID's
Old Feb 7, 2006 | 10:11 PM
Ramon's Avatar
Ramon
CL Folding 1,000,000
Default Brighter HID's
Hey everyone, this is my first (hopefully of many) post at clublexus and I've got a couple questions. Firstly I'm a pround new owner of a Black IS350, had it for just over two months and have already racked up 5k miles! and its not even my daily driver. Got an old 1998 pontiac I use most of the time to drive to school/work so needless to say i'm enjoying the IS a lot.
My first question is about HID's. I've been searching/browsing threads on here and have seen some pics of people with brighter HID's with the blueish/pupleish glow. Where can I get my hands on some of these?
Second question. I live in southern California, San Diego to be exact. Are there any dealers around here that sell and/or install aftermarket, or even factory upgrades for the IS?
Well thats it for the time being. My appoligies if these questions have been asked many times before. Thanks in advance for any advise!
-Ramon
Old Feb 7, 2006 | 10:25 PM
liquidsilver's Avatar
liquidsilver
-Ramon
The more blue/purple u get the more the light performance decreases. Stick to ur stock.
Old Feb 7, 2006 | 11:13 PM
Ramon's Avatar
Ramon
I realize the brigher HID's actually have less visable light, but I'm pretty envious of how bimmers for example look with their higher color temp lights. With foglights and high beams to fall back on if need be, I'm willing to sacrafice some of that visable light for the look
Old Feb 7, 2006 | 11:52 PM
rominl's Avatar
rominl
exclusive matchup
the hid on the IS (projectors) should have the bimmer effect already, no?
anyway you can do 6000k. it affects output a bit, though should still be fine
Old Feb 8, 2006 | 12:23 AM
Ramon's Avatar
Ramon
Yeah, that sounds like what I'm after. So now two more questions...
1) Is there a kit available that will allow me to keep the auto leveling and swivel feature that the stock ones have? While I'm willing to give up some light output for the higher temp HID's. I don't think I'd want to give up the leveling/swivel feature.
2) If there is such an animal, where do I get it?
Old Feb 8, 2006 | 12:25 AM
rominl's Avatar
rominl
exclusive matchup
?! you have hid stock already right? then you just need the bulbs
you can talk to xenondepot, or try jus4bulbs@yahoo.com
Old Feb 8, 2006 | 12:40 AM
Ramon's Avatar
Ramon
Yes, I have stock HID's... So all i'd have to do is change the bulb? Thats good news!
Forgive my ignorance, but this is my first day here... Is xenondepot a forum member or a website?
Old Feb 8, 2006 | 01:24 AM
rominl's Avatar
rominl
exclusive matchup
no problem, just ask!
yes you just need bulbs, all the autoleveling it has nothing to do with the bulbs
xenondepot.com is a vendor here. jus4bulbs, he's in taiwan, a lot of members got stuff from them before
Old Feb 8, 2006 | 01:37 AM
Neil64's Avatar
Neil64
Default HID bulbs are very expensive
I agree with Rominl, 6000K lights look great and that's what I will put in my car should I need to replace the OEM 4100-4300K HIDs but any quality (name brand such as Osram, Philips, etc) HID bulb is fairly expensive - couple hundred bucks for a new pair.
Neil
Old Feb 8, 2006 | 10:50 AM
T0ked's Avatar
T0ked
I thought the purple flickering on bimmers is mostly due to the lense in the projector, not the bulb itself. I have 5000k bulbs and the difference in light output from the 4300k ones I had before is pretty noticeable.
Old Feb 8, 2006 | 11:38 AM
G Star's Avatar
G Star
If you want to "look" like a bmw, you have to go with around 8000k.
If you want true performance oriented xenons - do a complete retrofit
The next best thing is 4300k. <-------you drive a lexus so class should be top priority . If you're on a budget, I'd recommend this one.
And if you truly feel bad about asking a question that has been asked many many times, try some searching. It really helps .
edit : my bad, just read you have stock HID's. Just stick to them man. You don't know it but you have the xenon flicker too when you drive. The main reason why you see it go crazy on bmw's and s2000's is because their suspension ride is stiffer.
Still ...search.
Old Feb 8, 2006 | 05:56 PM
Ramon's Avatar
Ramon
Thanks for all the advise guys. After doing some more research, I think I will be sticking with the stocks for the time being.
Oh, and class is a top priority If I do decide to do any type of mods, I'm gonna do it the right way and definatly not gonna go with a budget solution.
As far as searching, trust me, I do. Every question I ask I also do my own resarch on it. I like to have as many resources as possible to make an informed decision.
It wasn't necessarily the "flicker" I was after though, it was the color. BMW's seem to have a bluer output.
Old Feb 8, 2006 | 08:36 PM
blux's Avatar
blux
The output seems blue because of the cutoff, the color on the ground is pure white. There is a posibility that you can open up your stock projectors and modify the sheild/bowl to make the cutoff more colorful. Edit: Here is a thread from hidplanet showing the 06 GS headlights, maybe they are similar? Register and check the place out.
Here is a pic from HIDPLANET to speak 1000 words.
Old Feb 8, 2006 | 10:08 PM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
didnt somebody do a similar thing with the SC projectors using a custom spacer?
Old Feb 9, 2006 | 01:20 PM
corkycal's Avatar
corkycal
hmmmm, 50w ballasts will make things brighter
