Sponsored by: CARiD
Owners input on HID bulb conversion
Old Dec 25, 2005 | 08:17 PM
EUROJulian's Avatar
EUROJulian
Default Owners input on HID bulb conversion
Hi there! I`m looking for input on simple HID bulb conversion from actual SC owners. By simple I mean HID conversion with aftermarket xsenone bulbs fitting into 9006 sockets of oryginal SC projectors.
I want to do HID into my car for long time, very long time since project started, finaly I got tired of waiting.
I wanted to do it the "right" way on OEM parts and HID projectors. Unfortunately only one projectors I was able to find over all that time were RX330 ones. (buying parts on the e-bay is not for me, mostly because I`m cheap...) Those are on the large side, too much work to fit them into SC housings, realy do not have heart to cut them up.
After much of thinking I decided to look for other possibilities. I`m thinking aftermarket HID 9006 bulbs, D2 adaptors and my OEM ballasts.
How bulb conversion work for you guys?
Old Dec 25, 2005 | 08:29 PM
BLK13X's Avatar
BLK13X
For Mind Cruising
If I had the time, know how and patience to do an OEM retrofit I would've but I really can't because I lack all 3
I've got an HID kit in mine. It's made by MTEC with 6000K bulbs... looks nice. They emit a real nice white light and come with everything needed including the ballast holders. For me these will do until I get the courage to do an OEM retrofit.
Old Dec 25, 2005 | 09:10 PM
EUROJulian's Avatar
EUROJulian
I just really need the 9006 compatibile bulbs, since I have everything else.
Soarer, how does conversion compare to halogens you had before? are you geting negative feedback from incoming drivers?
Old Dec 25, 2005 | 09:27 PM
IronCobra's Avatar
IronCobra
I have an Osram HID kit with 4500k rebased 9006 bulbs. I'm using brand new headlight housings, so I also have a crisp cutoff line.
Old Dec 25, 2005 | 09:50 PM
BLK13X's Avatar
BLK13X
For Mind Cruising
It's interesting that the later models had a crisper cut-off line. I noticed that too between my old and new Soarers (both with HID kits).
EUROJulian,
I haven't really had much trouble with them. No one has high-beamed me or flashed their lights when mine are on. My stock halogen sucked, I couldn't see anything. If anything the real advantage of the HID's are the way they reflect road signs, lane markings and emergency vehicles. Much better than what my stock Koito halogens could ever muster.
Jose
Old Dec 25, 2005 | 10:42 PM
bcp_sc300's Avatar
bcp_sc300
Registered User
its all about HID
Old Dec 26, 2005 | 04:47 AM
BLK13X's Avatar
BLK13X
For Mind Cruising
Damn that thing is DUUUUUMPED!
Old Dec 26, 2005 | 06:59 AM
EUROJulian's Avatar
EUROJulian
I saw Philips bulbs 9006 compatible, oryginal with D2 connectors for sale. That is the last straw I think, OEM bulbs. They had side by side pic of both 9006 bulbs, halogen and HID, light element appeared to be placed in the same spot. I gues I`m redy to buy it.
It is interesting what you guys say about new and old projectors in SC, I took bunch of them appart and never noticed difference (proly because I didn`t looked for it or all those were "old"...) Many though had corroded parabolic mirrors, wonder if that may be it....
So when "new" type starts, what model year?
Old Dec 26, 2005 | 08:26 AM
IronCobra's Avatar
IronCobra
here is a whole thread on the newer headlights
https://www.clublexus.com/forums/sho...ight=headlight
Old Dec 26, 2005 | 10:17 AM
racinstyle's Avatar
racinstyle
I know what I will be ordering for my car after the new year
Old Dec 26, 2005 | 11:56 AM
EUROJulian's Avatar
EUROJulian
Ding! Thank you cobra. I missed that thread, thank you for the linkie. It all together sound like mature project now, worth the money
Old Dec 26, 2005 | 09:10 PM
sc400's Avatar
sc400
Hi,
Now that I've had my Philips 6000K HID kit for more than a year let me offer some qualitative observations. The HID kit is definitely brighter than anything non-HID. But since the SC's headlights weren't designed for a HID-type, namely its reflector and other parts aren't up to the task, its total light output is only a fraction of the real HID. Last night I drove my father's 2004 LS430 and oh my, its HID is bright! The total light output is amazing. For someone who have been driving with HID lights I thought I turned on the highbeams!
My sugestion? Try a non-HID replacement bulbs like Silverstar or whatever first to see if you like it because with $550 for a HID kit you're not getting your money worth. I'd say its light output is about 40% of the real HID. If you really want HID then get the whole headlamp replacements, not just the bulbs.
James
Old Dec 26, 2005 | 09:32 PM
IronCobra's Avatar
IronCobra
6000k wouldn't be as bright anyways.. The Color temp is too high.
I would have to disagree with you here. My 97+ headlights are just as bright as Audi and BMW Hids. I can even eclipse many of them when I pass them on the road. You are using the older style and therefore are getting a different output on the road. I guess you would be correct if you are only refering to 92-96 headlights and 97+ headlights that were made before 2000
This is because the 04+ LS430 has some of the brightest HIDs on the market. And the Widest beam. You would be hard pressed to find anything outside of a Infiniti Q45 with brighter lights than a new LS430.
I Totally disagree with this statement unless you are using pre 97+ headlights manufactured BEFORE 2000.
My output is AWESOME! and I am using brand new headlight housings with an Osram HID kit at 4500k bulbs.
Old Dec 27, 2005 | 05:31 PM
EUROJulian's Avatar
EUROJulian
Originally Posted by sc400
Hi,
James
I already have PIAAs and I had rebild my headlight, so mirrors are good, so my lights are OK, I just want HIDs.
Money wise I`m not spending that much, I just need Phillips bulbs, they go for $100 for a pair.
I may buy left headlight, right is alredy new, that additional $220
As for LS430, that is really expensive vehicle with humongous lights you choose to compare ageinst. I still have set of projectors from RX330, I may build "foglights" or something out of them. That would be a LS killer
Old Dec 27, 2005 | 08:43 PM
sc400's Avatar
sc400
If you had read my post carefully you'd notice that I didn't claim to speak for the entire SC family.
My comparison is based on my 96 SC400 with Philips 6000K HID.
Didn't know that Lexus made a HID projector headlights for the SC. Perhaps I'll find one of those to try out.
