Sponsored by: CARiD
yellow fogs???
Old Dec 19, 2005 | 07:48 PM
rominl's Avatar
rominl
exclusive matchup
yes it's just the housing, you get the bulb extra
Old Jan 3, 2006 | 01:07 PM
upstateGS4's Avatar
upstateGS4
Originally Posted by DetMich1
The part numbers listed in my previous post for the yellow OEM fog housings were for the housings only, No bulb is included.
is that part number for the clear housing with the yellow housing inside of it, or the all yellow fog inside and out?
Old Jan 3, 2006 | 02:18 PM
rominl's Avatar
rominl
exclusive matchup
there is no yellow housing inside of the clear housing, they are all just one whole unit, nothing to separate
so youeither get the housing with no yellow lens or one with yellow lens
Old Jan 4, 2006 | 01:11 AM
DetMich1's Avatar
DetMich1
Lexus makes two types of Fog lamps for the 2nd Gen GS. They both have a clear front lens. The yellow tinted lamps that come standard on cars equipped with HID headlights (note the HID is for the low beam headlights , not the Fog Lamps) are yellow tinted by virtue of a yellow colored enclosure that surrounds the bulb inside the fog lamp. The light emitting from the bulb is thus filtered yellow and both direct and reflected light shines on the roadway after passing through the clear front lens. The numbers I posted are for the fogs that come standard on cars equipped with HID syle headlights. If that is what you mean by "the clear housing with the yellow housing inside of it," the answer is yes. On the other hand , as far as I know, Lexus does not make a fog lamp that is "all yellow fog inside and out" If you have seen one like that perhaps the owner used one of those tinted films or spray on paints to convert clear fogs to yellow.
Bobby206
Jul 13, 2010 08:30 PM
LCDKikeIS
Jun 25, 2008 06:53 PM
sirblinks
Lighting
32
Sep 21, 2007 07:31 PM
effusion
Jun 9, 2007 09:52 PM
stacked14
15
Nov 20, 2005 10:12 AM
