What do you use to Seal your headlights? My turn signal assembly in my other car fell out of its housing and the clips that hold it in are broken, so basically I need to glue it back in place. What should I use?? I figured the same stuff used to seal headlights should provide a nice tight seal?
Bump, Bump
But not for the above, but its more about the topic.
I have to reseal the headlights on my uncle's LS after I clear up the moisture in them. What should I use to reseal the headlights afterwards? Also, I suppose I've got to put them in the oven to get them unsealed since I don't have a heat gun? What temp should the oven be, and for how long?
edit: Nevermind, I found my answer, searching really does help.
