Headlight Aiming
When facing the driver's side headlight, which screw adjusts the headlight vertically...the one on the left or the one on the right? Put another way, does the one tucked under the body a little control the vertical adjustment, or the one screw that is right out in plain view?
For anyone who's done this adjustment, you'll know what I'm talking about.
Thanks in advance.
All you had to do was type in Headlight Aiming in the search area and this thread would pop up with a picture for you....
https://www.clublexus.com/forums/sho...adlight+aiming
-Anthony
But I was still confused.
Is the vertical adjustment behind the frame, or the one out in the open? The picture with the Japanese writing shows all four bolts, but the writing is in Japanese so I didn't understand which bolt went where.
I know there's a vertical and a horizontal, I just want the vertical...for the low beam.
So, back to my original question...when facing the driver's side low beam, is it the bolt on the right behind the frame or the one to the left of the low beam out in the open?
I haven't been able to figure it out looking at any of the pictures, including the owner's manual.
Actually, I did do the search, and saw that thread.
-Anthony
So, it's the bolt behind the frame, to the right of the low beam (when facing the low beam). Got it.
