Sponsored by: CARiD
PIAA corners: poor quality
Old May 25, 2004 | 12:36 PM
persian451's Avatar
persian451
Default PIAA corners: poor quality
I wanted some good corner bulbs for my car using the wedge bulbs and everyone reccomends PIAA.. well here is what happens when you use PIAA after a couple months...
Old May 25, 2004 | 01:59 PM
siniquezu's Avatar
siniquezu
Yikes! I've never seen that before. I expected better quality from the price of PIAA. Are you sure there wasn't any water contact or anything?
Old May 25, 2004 | 02:30 PM
persian451's Avatar
persian451
yea pretty sure, my lower corners are liek that too.. i thought these were gas filled
Old May 25, 2004 | 09:02 PM
rominl's Avatar
rominl
exclusive matchup
umm this is weird, i have never seen that on the piaa before. seems like it's caused by heat.... it's a very small and pretty well insulated housing? and the place you inserted this bulb, you are supposed to use a 5w bulb there right?
Old May 25, 2004 | 11:22 PM
persian451's Avatar
persian451
thats right... it even happened in the other corners.. I dont get condesation, so i dont know what was the cause.
Old May 27, 2004 | 08:47 AM
CleanSC's Avatar
CleanSC
Post
My observations show that this is typical with Piaa on this size of bulb. The problem is they paint these.
I bought these at the same time with my 1157 Xtreme Whites to match the 194 Xtreme Whites (which they don't, the 1157 are noticeably greener). The 1157's are still there, and I'm on my THIRD set of PIAA 194's. I've just accepted the fact that these don't last and they are disposable. I think the 1157's are colored glass that's why they've lasted.
My PIAA Xtreme H3's for the fogs are flaking too. I suspect it's overheating. Some housings hold in heat more than others so maybe that's it? All I know is the 194's don't last over 6 months in my Celica.
I've decided to just stop using them all together. Not worth it. You just look stupid as it flakes and one light is a different color from the other side.
Old May 27, 2004 | 09:57 AM
siniquezu's Avatar
siniquezu
Does this apply to the yellow ones as well?
Old May 27, 2004 | 10:13 AM
persian451's Avatar
persian451
i wouldnt be surprised.. i am disappointed in piaa. charging so much for little quality
Old May 27, 2004 | 10:14 AM
CleanSC's Avatar
CleanSC
Post
My experience is with the Xtreme White line of bulbs...
I do have the Ion Yellow H3's in now and they seem to be working fine. I haven't pulled them out since I installed them new so I can't report on their condition. They seem to be working fine tho.
Old May 31, 2004 | 05:26 PM
AutoCoutureSC's Avatar
AutoCoutureSC
maybe the oils from your fingers from installation? i know that a lot of bulbs you buy, they recommend you not to touch the bulb with your bare hands. just a thought...
FYI.. my piaas are just fine.
Old May 31, 2004 | 10:08 PM
persian451's Avatar
persian451
could be a possibility
Fjaw
Lighting
Mar 11, 2011 05:18 PM
ArmyofOne
Lighting
Mar 23, 2005 08:49 PM
alsilverbullet
Lighting
Aug 8, 2004 10:25 AM
Taka
Feb 22, 2002 07:27 PM
